Results 1 to 10 of 12
Thread: which wire is + on lilliput egg
    Oct 2004
    i want to hardwire my lilliput to my car using the cigarette lighter adapter.. i cut off the end, and have two wires. One is completely black and the other wire has a white stripe. Which one is + and -
    I'm assuming the white stripe is positive but want to make sure.
    Newbie biglips31's Avatar
    Redwood City
    Take apart the end that plugs into the lighter. The wire that is
    solder to the pin is the +. Yes it is the white stripe.
    Carputer in design stage...
    Currently working on Lilliput In Dash Install...
    MII 12000 + 512Mb Ram + Panasonic Slim DVD, CDRW + Lilliput 7" + Opus 150W + 3.5 120gb Drive... most parts on order!!
    Constant Bitrate RPI Geek's Avatar
    Oct 2004
    Schenectady, NY
    I don't know for sure since my screen is coming in the next few days but what I'd do is just check it with a voltmeter / multimeter. They're relatively cheap and having one will help you install a carputer immensely.
    Old plans out the window because of an accident .
    Have: M1-ATX, EPIA M10000, 256MB, 60GB 2.5", slim slot load DVD
    Need: Time, HU integration, ideas for Lilli
    FLAC Chairboy's Avatar
    Jan 2004
    Consider skipping the egg and just wiring power directly from your computer power supply. The regulator in the egg cuts the voltage a little and affects screen brightness. Your ATX power supply should already be regulated 12v, and you can easilly make a molex plug that provides 12v without permanently modifying your PS.
    I do this for my car, my lilliput is powered off my Opus. Advantages, when I turn on the computer, the monitor powers on at the same time. Same with powering off.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Oct 2004
    ok i got it all working
    except i hooked it up to a wire that is only active when my lights are on.. oh well
    and chairboy, my pc is in the trunk and i didn't want to run more wires back there.
    Constant Bitrate naveedh's Avatar
    Oct 2004
    do not hard wire to your cigeratte lighter. This is because it is not a clean regulated voltage and it spikes up and one day it will fry your lilliput!
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Quote Originally Posted by naveedh
    Right, you'll still use the egg, correct?
    I did the same thing (with the egg) the screen flickered and actually caused unwanted noises. Better off doing what Chairboy said.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Constant Bitrate fallnangel's Avatar
    Richmond va
    ok i want to power my lilli throgh my atx psu but im not really that confident with doing it is there any visuals someone knows of or has that can give me detailed pictures if how to do this.thanx.
    ..and dont back out just because u think its too crazi , i hate pussies
    -outdidya
    epia m1000,256mb ddr,7"lilli,120gb hdd, Ati remote wonder,400watt inverter,350psu all under xp pro-installed
    Maximum Bitrate sfay93's Avatar
    Feb 2004
    Omaha, NE
    Buy a female molex to connect to one of the male power molexes from your psu. Wire it up so that the white stripe wire for the lilli goes to yellow and the other one goes to black. Plug it in and you are done. You could always cut the yellow and black wires from your psu and solder them to the correspoding lilli wires if you want to skip buying the molex.
    ATVMS.com
    Richmond va
    cool thanx for the fast reply
    -outdidya
  1. WTB: lilliput egg
    By asci01 in forum Classified Archive
    Last Post: 09-15-2004, 04:16 AM
  2. Quick Please - Lilliput Egg Wires - Installing Now
    By tbird2340 in forum LCD/Display
    Last Post: 09-09-2004, 08:33 AM
  3. Lilliput egg noise, solutions?
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-24-2004, 02:24 AM
  4. PSU to EGG to LILLIPUT ?
    By Danneman in forum LCD/Display
    Last Post: 06-20-2004, 02:45 AM
  5. Using Lilliput Egg to power HDD
    By alvins in forum Power Supplies
    Last Post: 05-03-2004, 10:44 PM
