Results 1 to 10 of 13
Thread: anyone put a lcd in a gauge pod?
    Sep 2003
    North Virginia
    i was wondering if anyone ever put a lcd display in a gauge pod?
    or mabey even a vacume display
    i wanted this as a aux display for my main display ( if its to bright or if i fell turning of the display)
    i was hopeing to display obd-ii , mabey track info, other stuff i cant think of.
    SWC
    SWC is offline
    Aug 2004
    Baltimore
    I haven't done this yet but I am planning on doing this on a 65 benz I got and I was planning on doing this. Only thing I haven't figured our which might put a wrench in the plan is how to get the speed of the car to be acurate since this was before obd was even thought about. GPS isnt a viable solution since it varies and isnt 100% acurate. I can't take the change of the GPS being wrong saying im doing 55 when im really doing 80. If I cant get a viable solution with PC I am going to use instruments from www.dakotadigital.com
    Sep 2003
    North Virginia
    you could do a speed sensor the car should have one
    at the very least you could wire tie a magnet to the axel and put a sensor to read the pulses
    measure out a mile in pulses / time vola
    FLAC Chairboy's Avatar
    Jan 2004
    GPS speed indication is very accurate, btw. Far more accurate then the mechanical gauges in most cars. Position, not as accurate. Altitude, far from accurate. But speed, yeah.
    Chrysler 300 - Fabricating
    http://hallert.net/
    Maximum Bitrate eCar™'s Avatar
    May 2003
    SE Michigan
    Quote Originally Posted by Chairboy
    Not if you want it to display your speed anywhere close to real time. If you let it average your speed for several seconds, it will be very accurate.
    Sep 2003
    North Virginia
    thread jack aside
    does anyone know a good usb lcd or vcd that fit in a gague pod
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by crash893
    thread jack aside
    Matrix Orbital + LCDC. I'm a LCDC programmer What GPS ap are you going to be using?
    Sep 2003
    North Virginia
    none yet
    i was going to have it be usb and run it off the computer rahter than directly from a devices
    Jul 2004
    Berkeley, CA
    none yet
    Yeh, Matrix Orbital LCDCs need a computer, and LCDC is a very good program for that Control over winamp, limited support for WMP, etc
    Sep 2003
    North Virginia
    what is the diffrences between lcd and the lcdc?
  1. Extending your laptop's LCD cable: FAQ
    By Yuriy in forum LCD/Display
    Last Post: 11-25-2008, 03:06 PM
  2. graphic LCD or PSOne LCD
    By hannibal in forum LCD/Display
    Last Post: 09-26-2004, 09:40 PM
  3. Where would you put an LCD in this dash?
    By redbeamer in forum Fabrication
    Last Post: 08-10-2004, 02:03 PM
  4. Mounting motherboard in WRX gauge pod housing..
    By Giuliano in forum General Hardware Discussion
    Last Post: 07-19-2004, 10:01 AM
  5. Replies: 4
    Last Post: 03-16-2002, 02:32 AM
