A bit pricey though...
The Epia M will be able to do both, but only at 60HZ refresh rate. My Lilliput has overscan problems at 60HZ (it runs fine at 75HZ) so this is what I purchased, a KWorld PC to TV converter:Originally Posted by Lattice
http://www.newegg.com/app/viewProduc...100-117&depa=0
It's $43 and outputs on both Composite and S-Video. I purchased two composite video headrest screens from DigitalWW for $120. Get an S-Video to composite adaptor, and now you can output the front screen output to both of the rears. The quality in the rear two LCDs aren't as good as the molded Lilliput in the front, but I only use it for the kids in the back.
This is the solution I came up with because my M10000 is in a Morex 3688 case, and there's no room to add a PCI card.
Installation Complete, pics soon
EPIA M10000 in Morex 3688 case
FrodoPlayer
CoPilot Live 8
Back from long hiatus, will be rebuilding soon
What, the $43 scan converter? It's not any more expensive than a PCI vga card.Originally Posted by Cris
FrodoPlayer
CoPilot Live 8
More expansive than an Y divider anyway...Originally Posted by ncamara
You still need a y divider to be able to use the liliput and the converter. But using the y divider and the converter is still probably cheaper than having to buy a vga monitor since you can find composite monitors for much cheaper.
EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
My Truckputer
That was what I was trying to get at. Like I had said, I spent $120 for TWO composite 7" screens. That's a lot cheaper than a 7" VGA. Even without touchscreen, they are around $250 for one. So for $170 I got two screens and the scan converter.Originally Posted by bbrother
You also don't need the Y cable because the model I linked to comes with a cable already.
FrodoPlayer
CoPilot Live 8
