Results 1 to 10 of 11
Thread: help with 9 pin connector
    Newbie bigrobb's Avatar
    Nov 2004
    From what I've been able to tell my LCD has a 9-pin Mini DIN connector.
    It's a durabrand LCD from the dual monitor kit sold at Wal-Mart, It was a partial theft recovery and the person stealing it got away with the DVD player, the cables and the other monitor, so I had the oportunity to buy just the monitor for 20 bucks.
    I need to know if it's possible to get an adapter or make this work with my computers VGA output, it's S-Video, or even a cheap DVD players RCA outs.
    I don't really care to have the sound from the built in speakers, or the ability to use the built in IR remote port. If possible I would rather gut the LCD from the housing containing all of that and only use the screen.
    Thanks if anyone can help me figure out how to get this working.
    May 2004
    NJ
    you did not mention male or female. but that doesn't mater since nothing else would work with it other than the original equipment.
    what you should do is to open the case, trace the wires and attempt to identify the function of each, most likely you would have 2 for power, 2 for audio and 2 or 4 for video (2 for composite - 4 for s-video)
    Welcome to the board.
    Nov 2004
    Thanks but...
    Thanks, and it's female but since that doesn't matter, how do I figure out what wire is what when I'm inside the housing?
    Constant Bitrate Vorex's Avatar
    Nov 2004
    Lake Worth, FL
    try calling "durabrand" and ask to purchase a replacement cable
    - Vorex Out
    Nov 2004
    But I don't have the dvd player I still need to know what to splice into where, right?
    Nov 2004
    I found the pinouts!!
    Now what kind of video signal do I put into the video input?
    Would RCA work, the prong is signal and the outside is ground, right?
    (Am I right that it wouldn't be S-video cause that's 4-prong?)
    I found the cable for six bucks, to cut and splice.
    Side note: When I found the cable I also found replacement screens, if I ordered this screen it would be $150 so I'm still up by $124 if I can get it to work. So I figure even at 6 inches I got a decent deal.
    Thanks for any help you can give...
    May 2004
    NJ
    RCA would work, the prong is Video and the outside is video ground, straight forward mapping, you got it.
    Listen up, if it is going to give you hard time I'll be welling to save you the headache, I will take it for $25 + shipping
    Nov 2004
    thanks...
    I lost the pinout for this after my hard drive toasted itself, good thing I could find my old post : ) hopefully it helps someone else out as well.
    I did get 2 cables for 5 bucks (leftovers from another theft), anyway thanks for the help...
    Newbie Prof_Fate's Avatar
    Dec 2007
    Seattle (Kenmore) Washington, USA
    Thanks for the tips
    I picked up a Durabrand 7" LCD screen at a thrift store, and was having a difficult time finding the pinouts for the socket.
    With your diagram, I now have the display working!
    -Gary
    Seattle
    Nov 2007
    bali
    @bigrobb : thanks for your diagram, shud work with my necvox lcd...
    great post!
  1. BMW E46 Owners with DSP systems and no HU
    By edrock200 in forum Newbie
    Last Post: 12-16-2006, 12:21 PM
  2. 50 pin to 40 pin connector for cd drives, supplier?
    By ruflyf in forum General Hardware Discussion
    Last Post: 03-12-2004, 12:23 AM
  3. do i need to use a 50- 40 pin connector?
    By DSM97RS in forum General Hardware Discussion
    Last Post: 03-08-2004, 08:15 AM
  4. 13 Pin DIN Connector
    By UncoCow in forum General Hardware Discussion
    Last Post: 11-21-2002, 06:46 PM
  5. Replies: 2
    Last Post: 10-07-2001, 12:43 PM
