Results 1 to 7 of 7
Thread: usb plug defective?
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    usb plug defective?
    every time I plug the touchscreen usb cable to the pc my system finds SIX new pieces of hardware, and none of them takes the right driver, they remains "unknown devices" and no way to make touchscreen work. I think my unit is defective, I tried to open it and clean each ribbon connection with no luck, any last idea before returning it for RMA? I really don't like the idea
    Low Bitrate got2liv4him's Avatar
    Oct 2004
    Gonzales, LA
    prob not the plug... probably the internal usb stuff in your ts... do you use any other usb stuff that works?
    Kimi ga kawareba, Seikaimo kawaru!
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Did you install the driver first?
    Installed the driver, then plugin the USB TS.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    might be a USB 2.0 controller and all that stuff it's finding is the USB controller.
    肚子笑痛了
    S60 Install
    Nov 2004
    Italy
    I use several usb pheriperals with no probs
    I tried on usb 1.x and 2.0, same problem
    I tried on several systems, one time in the exatc istant when I plugged the usb, the computer PSU got fried
    Variable Bitrate BiohazrD's Avatar
    Katy TX
    What TS are you using? If its a Lilliput, add another problem to the list. Also, try the new drivers, I've had problems where Windows thought the INF files were corrupted.
    Quick! To the Popemobile!
    Nov 2004
    Italy
    Yes it's a lilliput but I don't thint it's a software issue, on another machine with usb1.x I haven't been able to make my touch recognizer, I plug the usb connector and nothing happens
    I'm gonna take an RMA for it, I hope it is a 2 years warranty
  1. Problem with ITPS / hibernation and External USB HD
    By veetid in forum Power Supplies
    Last Post: 01-02-2006, 09:35 PM
  2. Will this layout with a remote USB hub work?
    By NoPistonPC in forum General Hardware Discussion
    Last Post: 08-21-2005, 04:24 PM
  3. usb male to female stub plug
    By dim-8 in forum General Hardware Discussion
    Last Post: 10-03-2004, 06:17 AM
  4. usb power problem: solved!
    By susman in forum General Hardware Discussion
    Last Post: 08-31-2004, 02:50 AM
  5. Replies: 4
    Last Post: 04-06-2004, 10:52 AM
