Results 1 to 6 of 6
Thread: DWW-7VGA questions
    DWW-7VGA questions
    hey, ordered one of these from Armen. in prep for it coming, i need to know what the hookups are so i can order the cables/connectors. what type of USB cable will i need coming off my USB hub? does it just have a female DB15 vga input? an electronic copy of the manual would be the best if it is around, i couldn't find it.
    Craig
    Oct 2004
    Quote Originally Posted by Craig W
    There's a standard male VGA connector of the type one would connect to a VGA card, a standard USB plug of the type one would connect to a USB hub or computer, three RCA jacks which appear to be inputs which I have never used, and bare wires for the power. It's quite normal stuff, you just need a VGA extension cable and a USB extension cable.
    Weirdo, thanks buddy.
    so basically, i will need a VGA extension cable with female on one side and male on the other.
    for USB, is it a male to male "A" cable?
    thanks again.
    Craig
    Maximum Bitrate Change's Avatar
    Aug 2004
    California
    For the USB cable, you may want something like this: http://www.ramelectronics.net/html/CAB-USB-6-16.htm
    USB spec says about 16 feet maximum between active components...
    You can also use a USB hub if you want, probably costs about the same.
    Oct 2004
    You need an extension type USB cable (female to male) like the one to which Change posted a link.
    thanks guys, much appreciated! now i can get going ordering stuff..
    Craig
  1. Lots of questions.. long post.
    By rach in forum Newbie
    Last Post: 11-13-2004, 10:53 PM
  2. ODB-II Questions
    By quickshot56 in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 10-29-2004, 09:10 AM
  3. starting my first carputer project, have some questions
    By ssa_whiskey in forum General Hardware Discussion
    Last Post: 02-24-2004, 02:43 PM
  4. Additional questions about LCDs: Is 400 nit too bright?
    By khiser0001 in forum LCD/Display
    Last Post: 05-06-2003, 07:13 PM
  5. starting project soon, questions..
    By tekknikal in forum General Hardware Discussion
    Last Post: 05-28-2002, 06:47 PM
