Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Rotating My Display....
    Oct 2004
    S.Yorks // UK
    I need to flip the picture on my screen so i can mount my screen upside down,does any one have any ideas???
    Andy
    PC --Epia m10k ,7" Liliput Touch screen,512ddr ,80gb 7200 8mb cache shock technology hdd ,54mbit USB2 wlan
    ICE -- JBL 755.6 Amp, JBL p93 6x9s ,JBL 506c Components ,JBL GT3 12" 1800w Sub, 4AWG Cabling,Uprated Battery
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    if you have an ati card the drivers can do this for you. dunno about other makes
    Oct 2004
    S.Yorks // UK
    i have a M10000 epia thingy :S
    Really need to no
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Pivot Pro http://personalcomputing.portrait.com/us/products/
    When it's rotated in software though it will impact speed, probably not an issue for most things other than DVD/Movie playback.
    Oct 2004
    S.Yorks // UK
    how awkard would it be to turn round the actual LCD inside the lilliput?
    Oct 2004
    S.Yorks // UK
    gunna try this first ...
    http://www.bluechillies.com/download.html?sid=11887
    ne1 know about my above question?
    Oct 2004
    S.Yorks // UK
    right...jus took the screwsout of my screen to have a look if i can turn my screen around, but noticed a small sticker on the bottom,has no warranty void writtin on it tho,jus says lilput an some numbers,will i be ok removing/tearing it?
    Maximum Bitrate eCarô's Avatar
    May 2003
    SE Michigan
    Don't know anything about the Lilliput. If you can get a hold of the datasheet, you might find that it has something like this option on my NEC (see attached pic). I cut wire #38 on the hirose connector, and the picture flips upside down.
    Make sure you do that with the power off!
    Jul 2004
    Rancho Cucamonga, CA
    Why is it so important that you rotate your screen upside down, are you sure you cant mount it normally???
    EPIA MII-1200, 512 MB Ram, Seagate 7200 RPM 160GB hard drive, Orinoco Gold with 5.5 dB external antenna, Lilliput 7" TS, DVD-ROM, M2-ATX, Rikaline 6010 GPS, Running Frodo Player
    My Truckputer
    Oct 2004
    S.Yorks // UK
    hoirse conector,whats one of these? :S Does any1 have any clues on this???
    I really cud do with flippin it,i tried that pivot thing,an video playback is pants :S
  1. Matrix Orbital GLK-12232 Display Software
    By dug1967 in forum General Hardware Discussion
    Last Post: 08-15-2006, 12:10 PM
  2. Display brightness
    By ozoffi in forum LCD/Display
    Last Post: 05-14-2004, 05:12 PM
  3. Any way to relocate my display card??
    By SlimJimmy in forum General Hardware Discussion
    Last Post: 03-22-2004, 09:14 PM
  4. Choosing a Character display...
    By Kryten in forum LCD/Display
    Last Post: 10-16-2003, 10:43 PM
  5. Video cards that display NTSC on boot?
    By Squeezer in forum General Hardware Discussion
    Last Post: 01-06-2001, 10:56 PM
