Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Building a motorised screen without motors???
    FLAC NiN^_^NiN's Avatar
    Aug 2004
    Australia, Melbourne
    Ok guys im building my own LCD holder but it will work like a motorised LCD but it wont have motors.
    The basic idea is to make a LCD slide out and up then u must manually fold the LCD down and push it back in when done.
    So what im doing is building a case for this to slide out and open up.
    The theory behind this is SPRINGS yeah im not crazy :P
    What happens is when the LCD is pushed inside the case the spring streches so when u push the button to open the LCD the spring contracts and slides the LCD out of the case.
    Ok so the spind just slides the LCD out right?
    Then we have another spring which pulls the top of the LCD backwards to the case ro open set the LCD in view.
    There will be a small wheel with foam on it at the top of the case so the LCD slides out smoothly and then when the end finally gets out it will angle the LCD so u can view it.
    I will start building this soon and yes it will work some basic testing has been done and i have thought bout it all like slowing the speed the LCD slides out etc.
    So what do u guys think?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    rum
    rum is offline
    Newbie rum's Avatar
    Mar 2004
    Wezep, The Netherlands
    I say: nice project! But I have one question... The distance between the screen and your dash... won't that be much? I like your idea on using springs, I have been thinking about this too...
    Oct 2004
    Hmm, nice one!!
    My question would be how well would the springs work when it's coming up?
    It's not gonna be smooth right? You'll need to push it beyond a point before the springs kick in and then it's gonna just suddenly spring up.. I think you need some way of dampening it... LEGO technics hydrolics?
    Aug 2004
    Yeah iv got a way to dampen it.
    When the LCD slides out the Spring will be very tense what will happen is there will be a rail on the part that slides out which is going to be connected to alot of cogs which slow it down as it slides out.
    I don't know how to draw it im probably not explaing it right
    But the sliding out will be smooth cause of the cogs then the LCD will angle up pretty smoothly but i need to work that out a bit more.
    Also the space between the dash and the LCD won't be that much as i plan to have it in the dash further and a fake cassette face so no1 will steal it :P
    Or i might make a front which looks like the face has been removed so they wont bother trying to get it.
    You could just use a OLD cdrom drive to slide the LCD out then the spring to make the LCD angle up
    Did I actually answer your questions? lol
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Jun 2004
    Bay Area, California
    have you checked out digital world wide? they have the DIN casing already built, springs and all....
    Aug 2004
    Does the LCD automaticlly slideout and swivel up with the springs?
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    are you sure that the springs would slide the LCD out rather than shoot it out. It needs some sort of a damping mechanism like perhaps a flywheel after the cogs.
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Newbie tekkno's Avatar
    Nov 2004
    But not in stock......
    graham:-)
    Aug 2004
    Quote Originally Posted by choyak
    Yeah it will slide out not shoot out I'v thought it all through just need to get some parts and start building.
    The spring slides the LCD out which is connected to the Cogs which is connected to the damping mechanisn so it wont just spring out and hit u in the head
    When i have it made and have it all working properly i'll put up a lil how-to on building 1.
    I could just build a motorised 1 if i wanted to but i dont have enough time to do that then build a PIC to control it.
    Altho anyone could build a motorised 1 as u can get PIC kits for like $20 then u just need to get the right motor then hook it up through a pulley type of system
    CarPC Status:
    GPS: 99%
    Hardware: 99%
    Software: 92%
    Case Install: 99.9%
    Dash Install: 100%
    Car Install: 72%
    Jun 2004
  1. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  2. What the....same screen? Good screen?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-31-2004, 12:37 AM
  3. Touch screen motorised VGA display.
    By chenko in forum LCD/Display
    Last Post: 03-25-2004, 09:07 PM
  4. screen help
    By XCURSN in forum LCD/Display
    Last Post: 06-24-2002, 12:10 PM
  5. Redant screen - widescreen, screen res, TV out???
    By Griffin_Dodd in forum General Hardware Discussion
    Last Post: 02-06-2002, 07:09 PM
