Powerstrip settings for running your Xenarc in native 800*480 resolution & manufacturer's FAQ:
http://www.xenarc.com/faq.html#QA1
Q: How do I
power my Xenarc using the molex plug on my power supply? (safer, regulated power)
A: Chop off the power connector of the included cigarette lighter adapter. The inner set of wires is your positive and the surrounding layer of wires is your
negative/ground. Twist these into separate positive/negative strands.
Connect the positive strand to the yellow wire on a
male molex connector. Connect the negative strand to either black wire on the male molex connector. Plug it in to one of the female molex
connectors on your power supply and you should be good to go!
If you do not want to destroy the Xenarc's cigarette lighter adapter, you can also substitute any other power adapter that uses the same style plug. The
wiring will most likely be a little different, but you still have a 50/50 chance of guessing the right polarity.
