Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
Thread: FAQ: Everything you need to know about your Xenarc
  1. #41
    Maximum Bitrate Injector's Avatar
    Mar 2005
    Rockledge, FL
    Quote Originally Posted by coffeejolts View Post
    Xenarc has changed the timing settings they list on their site for the 700 series. If you have an older monitor, you might want to try these old ones instead.
    what software is that?
  2. #42
    Nov 2007
    PowerStrip (note the brand in the lower-left corner) is very useful software for adjusting low-level settings.
  3. #43
    Constant Bitrate Pseudo Nim's Avatar
    Apr 2005
    in the snow
    I don't understand why it's so hard to get the FEMALE version of the MDR plug - it's madness. For some reason, it seems nobody makes extensions of these cables.
    Well, at the very least, an alternative to the link above to source the plug parts is here: http://www.mouser.com, part #'s 517-10120-3000PE for the plug and 517-10320-52A0-008 for the plastic shell; and then there's about 10 million variations for boardmount, angle mount, etc. But all male; if you want a female one, it seems you MUST get a boardmount, can't get a solderable one. I'm trying to make an extension for the cable, so I ended up buying a panel mount female, and will see if I can somehow manage to solder the wires onto it.
    Doko ni datte, hito wa tsunagatte iru...
    My BMW 335xi install
    My Subaru Impreza install (now retired...)
    Realtime audio freestyle hiphop battles online - www.letsbeef.com!
  4. #44
    Apr 2005
    in the snow
    Update: ribbon cable DOES NOT WORK. I dunno if it's because 28AWG is too thin for the wires, or there's crosstalk, or what. But I used the connectors in my post above to build a custom ribbon cable (about 10ft long, wired straight through, pin1->pin1, pin20->pin20, which is how the original cable checks out with an ohm-meter), and I get nothing. Monitor powers up, flashes "no signal", then the speaker starts buzzing. Grr.
  5. #45
    Jul 2014
    Xenarc 700CSH 26 pin breakout
    Hi, not sure this is the right thread, but here is the schematic of the 26 pin cable for the Xenarc 700CSH, broken out to DVI, USB, VGA, 3xRCA and 3.5mm jack connectors:
    Name:  Xenarc 700CSH breakout board v1.0.jpg
    The plug can be found here:
    http://www.newark.com/3m/10126-3000p...pos/dp/80K6510
    The shell:
    http://www.newark.com/3m/10320-52f0-...ter/dp/50B8703
    The PCB receptacle:
    http://www.newark.com/3m/10226-55g3p...cle/dp/93K6331
    I only tested the DVI and USB connectors, please let me know if you find mistakes. If anyone wants the eagle files, send me a PM.
  1. Xenarc direct cause of audio noise- help!
    By shidarin in forum LCD/Display
    Last Post: 04-19-2008, 10:53 AM
  2. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  3. Xenarc VGA Controller Features
    By 1300mer in forum LCD/Display
    Last Post: 07-05-2004, 01:46 PM
  4. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
