Results 1 to 10 of 14
Thread: Any 7" VGA and Composite touchscreen monitors with trigger for reverse camera?
    Variable Bitrate rgardjr's Avatar
    Oct 2003
    I spent some time searching and didn't find anything along the lines of Xenarc or Lilliput having a built in trigger to switch inputs for a reverse camera. Has any one come accross any. I've seen some composite screens that have this feature, but nothing with VGA/touchscreen. I was playing around with a Lexus GX470 last weekend that had this feature and I thought it was very cool.
    '03 Sierra Denali
    Variable Bitrate egeekial's Avatar
    May 2004
    I'm not sure of the details, but you can use for carputer to do it instead of the screen.
    Oct 2003
    Quote Originally Posted by egeekial
    I've read a little bit about using some of Frodos great applications to accomplish this via software using a net cam. The net cam is a little bit of a problem for me because I'll be mounting this on the tailgate/back of a pickup truck.
    '03 Sierra Denali
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    @egeekial: The most common backup maneuver is right after you start the car. For most people, boot times are slow enough that by the time the pc is ready to play, they will already be done driving backwards. That's why people are looking for a direct hardware approach.
    To answer the OPs question, there aren't any built-in triggers to do what you want. So far, I haven't seen any mods to do the trick either. You could build something that counts pulses on the video input button but without some sort of feedback mechanism, it would likely get out of sync -- and thus be useless. Perhaps somebody will hack around their Lilliput with a scope and fine a suitable point to attack this mod.
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Get one of those VGA boxes that will let you switch modes.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Tainted Love Cris's Avatar
    Romania
    What about this: http://www.cartft.com/carpc/catalog/il/395
    It's supposed to automaticlly switch to the rear cam...
    May 2004
    NJ
    Quote Originally Posted by Cris
    That would not cut it, it does not take VGA.
    Romania
    Quote Originally Posted by kingtut
    Not sure if it will work either. I just ordered it, but, like the screen, it's not here yet. They said it would work fine...
    How many VGA cameras do you know?
    Dec 2003
    Surrey, BC, Canada
    I'm wondering if maybe you could use a shutdown controller... the "remote" input could be hooked up the the reverse lights or something similar and the atx-output hooked up to the "input" button of your screen. But I'm not sure if the "input" button accepts the same voltage as an atx pulse, or even if the shutdown controller delivers voltage or if it just shorts the 2 pins that are connected to it...
    Also, I guess it would have to send 1 pulse when the line goes high (to switch to input 1) and then 2 when the line goes low (to switch to input2 and then to VGA). Just an idea... might work with some modifications.
    Low Bitrate ernie's Avatar
    Jul 2004
    Poland
    I think Xenarc has this abiliti. I read on the forums that it has video2 priority, so when there is signal, it cuts vga or video1 and switches to video2, so all you have to do is plug camera into video2 and power it from your rear light.
  1. VGA vs RCA & Touchscreen vs other
    By integsrtite in forum LCD/Display
    Last Post: 12-02-2004, 06:07 PM
  2. Replies: 0
    Last Post: 09-27-2004, 07:07 AM
  3. Starvision 7" VGA touchscreen pictures/review
    By NoPistonPC in forum LCD/Display
    Last Post: 08-31-2004, 03:26 AM
  4. vga -> composite -> vga (possible?)
    By Nav_Attack in forum LCD/Display
    Last Post: 04-03-2004, 11:38 AM
  5. 7" composite or 15" true vga lcd?
    By cdm in forum LCD/Display
    Last Post: 11-26-2003, 01:45 PM
