Results 1 to 10 of 10
Thread: Do all touchscreen use a USB to connect?
    Newbie SpyderJL's Avatar
    Dec 2004
    OR
    Question Do all touchscreen use a USB to connect?
    Hey guys, I was wondering if all touchscreen LCD's use a USB or PS2 to send the info. from the touchscreen to the computer?
    I know the use a VGA, S-Video, Serial port, or RCA to send the video signal but is the touchscreen feature only sent through USB or PS2?
    Or are there ones that send all the info through a VGA or Serial port??
    Thanks for any help,
    Justus
    BTW did searching (but only a 4-5 hrs. worth )
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    some are serial, older ones.
    Dec 2004
    OR
    Question
    Quote Originally Posted by lez
    ^ the touchscreen application uses a serial port to transmit data to the computer or the display uses a serial port??
    Thanks for the reply,
    Justus
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    dunno if you can use a serial to usb adapter buti think cartft has some serial ones.
    Dec 2004
    OR
    The reason I ask is b/c I want to have just one cable that transfers the data to the video and from the touchscreen.
    But so far all of the screens use two seperate cables
    Thanks Justus
    Nov 2004
    Cali
    The only screen that I know of that sent USB and video signal at the same time is Apple Cinema (actually it also carried power). Other than that, you would have to look at some proprietary setup to find a one-cable solution.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    You won't find anything like that for a standard PC. Your video data will always be on a separate cable then any controller data. You can make your own cable and connector and just combine and separate all the lines at both ends.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Elsewhere
    Quote Originally Posted by SpyderJL
    Tough. The screens require one cable for the VGA display signal and one for the touchscreen control.
    How about the Wiki?
    Dec 2004
    OR
    Oh well thanks for the info guys I'll just work around it.
    Justus
    Jul 2000
    SpyderJL,
    Your touchscreen is an input device just like a keyboard or mouse. You remember serial mice right?
    -K
  1. Earthmate USB to Serial cable
    By New_Compact in forum GPS
    Last Post: 05-22-2008, 01:55 AM
  2. FS: 8.4" LCD with USB touchscreen
    By lzrdkng14 in forum Classified Archive
    Last Post: 05-28-2004, 03:40 PM
  3. Replies: 4
    Last Post: 04-06-2004, 09:52 AM
  4. hooking up laptop to usb touchscreen
    By rjahr01 in forum LCD/Display
    Last Post: 10-16-2003, 08:22 PM
  5. Trade: 8" VGA USB Touchscreen *for* 10.4" VGA touchscreen.
    By Euclid in forum Classified Archive
    Last Post: 02-10-2003, 10:43 PM
