I am trying to add support for LCD's in my application. I acquired this LCD from the front of an old server at work. I searched google and think I found the specs.
http://www.fluxmedia.net/downloads/dv20200.pdf
The specs talk about it having 16 pins, but when it was connected on the server there was only a 14 pin connector that plugged into the pins on the left hand side of the front picture. The other two pins mentioned are A and K, which you can see on the left hand side of the back picture, but nothing was hooked up there and they aren't pins. I am no good with hardware modding. I need to interface it with serial or parallel, not sure which one, in order to use it. I know nothing about this stuff, so I need someone to help me make a cable to be able to use this on my computer. I can send the LCD it to anyone if need be.
Is this the kind of LCD other people use? This should be possible and work right?
http://www.fluxmedia.net/downloads/lcdback.jpg
http://www.fluxmedia.net/downloads/lcdfront.jpg
david
01001101010100000011001101000011011000010111001000 1000000101001001101111011000110110101101110011
Thanks for the info... I found a bunch of information, but there was so many different ways to wire it. Which one should I choose? I want to set this up in the same way as other people in the forum, so when I write the code to communicate with it, it will be compatible. Also... What is all the talk about how many keypads it supports? I admit I know nothing about this stuff and sorry if these are basic questions...
Is this the one I should follow:
http://www.markuszehnder.ch/projects...allel_8bit.gif
I am also not sure about whether mine is an 8 bit display, like it mentions..
If that is the picture to follow, then everything looks fine except There are some that are labeled different. My top three are Vss, Vdd, Vee. The ones in the image are Vss, Vcc, VLc. Does this matter? I also don't understand what is going on with the pins 18-25 on the printer port.... It has all those linked to the ground and power. It also looks like they wired VLc someway into the same as the Vcc (5v). This one is labeled Vee for LCD Drive on mine. How does that work.
I understand wiring the RS, RW, E, DB0-DB7. I assume I do nothing with the VB+ & VB-, they represent my A & K. Then just run my Vss (ground) to some ground port on the printer connector (which is it) and supply 5V to the one wire Vdd (why was this wired into the printer connector in the photo). Also not sure what to do with the lcd drive Vee.
thanks
*bump*
I've never used one but I believe
Vss - GND
Vdd - Power supply
Vee - Contrast adjust
You set the contrast by adjusting the Vee voltage between Vss and Vdd.
Be very careful with the contrast adjust. I.e research it WELL before putting power to it. I have a lcd that the contrast is between 0 and -5v. So 5v made one LCD go puff.
Like rando mentioned above
Vdd = Vcc = +5V
Vss = Gnd = 0V
Vee = VLc = depends on the LCD but most will work between 0-5v
As for pins 18-25 they are the ground on the printer port.
You will need to steal power from one of the drive connectors as the Printer port does not supply any, the red wire on the HD connector is +5V and any of the Black ones is the Gnd.
As for Vee just connect it to ground. If you want to adjust the contrast then connect a 10-20K potentiometer between +5V and Gnd then take the wiper of the pot and connect it to the Vee terminal.
I hope this helps and good luck
I appreciate everyones help... I wired it all up today and it works great... Here is a pic of it running and another of the cable I made... I connected a DC plug for the 5V power source. Now I can get power from multiple places. I have a bunch of cables with dc plugs. I have one for the keyboard port, a usb one, and a molex one...
Great job![]()
I like the way all wires are nice and tidy! You really pay attention to detail me like it a lot![]()
