Results 1 to 2 of 2
Thread: Problem with Lilliput and white screen
    Nov 2004
    Finally got all the components of the carputer back together last night, including new OPUS 150, camera, etc...
    I have the lilliput running off 12V supply with OPUS.
    Last night I started and shut off the unit at least 10 times with no problems.
    On the way to work, i decided to capture my first vid - at this point, everthing was running over an hour... a couple of seconds after I pushed the capture button, screen went white. turning monitor off and on makes everything work normal. If I reboot, screen goes white again - then turn the monitor off and on, and everything is normal. Did this several times to test.
    I did a search and found alot of links about the ribbon cable being bad, but it seems odd that repowering the monitor makes the problem go away...
    One more detail. This monitor has the button panel shorted so it turns on when power is applied.
    Any ideas?
    Nov 2004
    started the carputer 3 more times, and all is normal. Don't know if I'm happy or sad
  1. Can't calibrate lilliput touch screen
    By _wd in forum LCD/Display
    Last Post: 02-14-2007, 11:10 PM
  2. Broken lilliput controller ?
    By Soul in forum LCD/Display
    Last Post: 12-13-2004, 05:44 PM
  3. Lilliput and ribbon cable problems
    By Udonboy in forum LCD/Display
    Last Post: 11-08-2004, 08:24 PM
  4. My 'brand new' lilliput is 2nd hand????
    By JayKaye in forum LCD/Display
    Last Post: 04-21-2004, 01:14 PM
  5. Lilliput ghost
    By spectrumzz in forum LCD/Display
    Last Post: 11-26-2003, 06:18 PM
