Results 1 to 8 of 8
Thread: HELP Stuck on a Black Screen
    Jul 2004
    I was disabling my onboard video from the
    Control Panel/Settings/advance/Adapter and then shut down installed the PCI slot VIdeo card and Booted up. It reconized the new PCI video card and THen booted up. It showed the Compaq Screen and I get a Black screen I hear windows Start up Music but no picture. So then I remove the PCI card and See if It will start up with the onboard but I get the same black screen. It is a Compaq deskpro en 1ghz.
    Low Bitrate Wolfman's Avatar
    Nov 2003
    East Texas
    Its been a long time since I messed with disabling on board video. You have to follow a certain sequence and I don't remember what it is. Start in Safe Mode to get your video back.
    Nov 2003
    East Texas
    Try this....
    http://hardware.mcse.ms/message112736.html
    a few posts down
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I had something similar happen to me when installing my PCI video card. Turns out that the computer Display setting recognizes both the onboard video and the PCI card as legit video. I had to hook the CRT up to the onboard video port to get the video picture. After that, I went to Settings-->Display and switched the primary screen to the PCI card. Then rebooted and that fixed it.
    Want to:
    Jul 2004
    Quote Originally Posted by Bugbyte
    I rebooted with my CRT hooked into the onboard but same black screen??
    Jul 2004
    Quote Originally Posted by Wolfman
    WHen I start in Safe mode It just gets stuck in the text part when its checking the Drives
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Quote Originally Posted by Boostz21
    Ouch. Before I somehow magically figured out how to set one as primary, I got stuck in the same loop as you and eventually had to reload the operating system, use the onboard VGA, load the PCI drivers, set the PCI board to primary, then turned on mirroring and then I could use both outputs.
    But as I said, I had to reload the operating system to do it. I couldn't reboot in safe mode either.
    Want to:
    Jul 2004
    Thats what I was afraid of. I think I might pull the HD out and Put in my other PC TO pull out all my programs and Stuff. DAM This Sucks
  1. Replies: 21
    Last Post: 08-27-2006, 02:26 AM
  2. Gamecube screen
    By junior in forum LCD/Display
    Last Post: 11-24-2003, 07:38 AM
  3. screen help
    By XCURSN in forum LCD/Display
    Last Post: 06-24-2002, 12:10 PM
  4. 6.4 " non working screen
    By prado_sergio in forum General Hardware Discussion
    Last Post: 01-17-2000, 07:36 PM
