Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Monitor not powering up. Help!
    Feb 2004
    Las Vegas, NV
    Attached are pics of my monitor. Yes, it's a Pyle, but I had trouble finding an in-dash 4:3 monitor. I can't stand the "squishiness" from a 16:9 monitor, especially when you're playing a video game. It's a stop-gap measure until Xenarc comes out with their touch screen in-dash. Anyway, I can't get the unit to power up. I've attached it to a 12V source (a spliced molex connector from my computer) and I've measured the voltage going to the wires to be 11.98V. I had this problem with the first unit, returned it thinking it was DOA, but then this second unit doesn't power up either, so I'm guessing I'm missing something. Any suggestions would be greatly appreciated. I've tried completing the parking brake circuit as well, but with no luck. Besides, shouldn't I at least get the LCD clock display to power up with or without the green parking brake wire?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    well obviously just ground the green wire rather then hooking it up to the parking break (for TESTING purposes). Also, check the fuse on the red wire.
    PC Components:
    My work log
    Dec 2004
    Maryland
    I dont understand what the yellow backup would be for
    PC Components:
    My work log
    Oct 2002
    St. Louis, MO
    I believe its used to automatically switch the screen to a rear view camera when you shift into reverse.
    edit: its believe not beleve
    2008 Grand Prix GXP
    • Winbook TW801 8" Windows 8.1 Tablet
    • RF 3Sixty.3
    • 4ch Alpine on factory bi-amped Monsoon speakers
    • Directed HD-Radio
    • I need to post a built log
    Feb 2004
    Las Vegas, NV
    Anybody have any idea what that little rod thing is in the diagram (between the red 12V and the batt)?
    Feb 2004
    Las Vegas, NV
    Quote Originally Posted by Peoples
    Checked both. Resistance between fuse was less than 0.5 Ohms.
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    Ok, a little car stereo info...
    Red is switched power...key on ignition. (I think that is a KEY symbol)
    Yellow is constant 12v. Must have a clock or something to keep powered up.
    Black is ground.
    Green goes to ground to let the unit turn on when the brake is applied.
    To test, connect the black and green to 12v NEGATIVE
    and connect red and yellow to 12v POSITIVE
    2005 Ford Focus ST
    Dec 2004
    Maryland
    Well thats what i thought the yellow was at first until timothy's post, and then i looked at the diagram and noticed the AV2, rear view video input
    PC Components:
    My work log
    Nov 2004
    Yah you need to connect the green to a ground... let us know what happens.
    Low Bitrate core212's Avatar
    Jul 2004
    New York City
    i'm having the same problem with my monitor which is a tview t-700ts but mine only has two connectors for power. one black, and one red... i can't get it to power up at all and initially it did power up for me once before but i've tried again and again since then and nothing. what could be the problem? the way i connected it the first time was using the power supply from my pc which i tapped the red and black wires on and it powered up. what could you guys tell me about this? i'm about to give up on it and order a lilliput but i'm down to my last dollar with this project and i'm losing faith fast!
  1. A solution for powering 12v stuff inside
    By zootjeff in forum Power Supplies
    Last Post: 12-17-2004, 06:21 PM
  2. Powering Laptop with the Car Battery
    By mintee in forum Power Supplies
    Last Post: 11-29-2004, 07:38 PM
  3. Powering a datalux screen from atx psu
    By Speedpass101 in forum Power Supplies
    Last Post: 10-08-2004, 03:19 AM
  4. Powering an optical Drive ?
    By 59fire in forum General Hardware Discussion
    Last Post: 06-13-2004, 08:04 PM
  5. Opus 150 and PW-70a powering one carputer
    By Altimat in forum Power Supplies
    Last Post: 05-19-2004, 11:43 AM
