that led should not kill ur battery if u drive the car everyday... i wouldn't worry
I just put my Lilliput screen in my car and have it hardwired to the cigarette lighter, which has constant power even when the car is off. When the screen is turneed off the little green power light goes red as you all know.
I'm assuming that's just a little LED light in there that has no significant power usage, but could that drain the car battery in any way shape or form?
the use of power of that led is really small....think about the led that flash all the time from you alarm system. even if you don't drive you car everyday it won't do nothing to your battery.
Here's another question on that same line of thought that came up while I was installing it.
I kept hitting the power button while I was fiddling with it. The screen would come on for a few seconds, tell me there was no VGA signal, then go complete blank and the blue buttons would shut off. No backlight or anything. But the powerlight was green.
In that state is is using any power? Would I have to even turn the screen off when I got out of the car? Since is APPEARS to be in the same state as when the red light is on.
When the car turns off the computer should go off with it, thus making the monitor think it has no VGA input, thus sending it to that seemingly powered down state.
Signature: [==||========] 20% complete
Well that answeres thatOriginally Posted by Nic
Now it's just a matter of remembering to turn it off. Hmmm...
I don't want the screen to turn on with the car, yet I want it to be off when the car shuts off. Hmm....
Plug it into your PSU. It'll be on when your computer is onOriginally Posted by Skipjacks
If it was plugged into the computer, would it automatically turn on when the computer turned on? Or would I still have to hit the power button? Obviously when the computer turned off I would think the monitor would go completely dead, no red LED or anything becaus I'd think it would have no power at all.Originally Posted by 0l33l
If that's the case I'd have to turn it on myself but it would shut down automatically. Right?
Damn I wish I would have forseen the whole "make sure you turn it off" problem before I installed the screen tonight. Getting it in the dash once was enough of a pain in the ***.
