Did you run the auto adjust feature on the LCD?
So i've read up on this and I'm wondering if this is a solveable problem.
Xenarc 7" touchscreen
MII1200000 with stock video, i think the most current drivers.
So i'm stuck running 800X600@75hz.
it doesn't look bad.. But when i put on an extension cord (any vga extension, i even tried a hommeade one, all lengths), The picture gets blurrier. It's still usable, but fairly noticable.
Anyone seen this or have any idea if it's solveable?
Yup.. repeatedly..
I would try a high quality monitor extension cable. Most likely you are trying a thin cable with poor insulation.
Any recommendations? Preferably with a store?![]()
The one i'm using is from Radio Shack, but they are expensive. Just go into any computer store and you should be able to tell how good they are insulated by their thickness.
Look at the official Xenarc extension cable. http://www.mp3car.com/store/product_...products_id=64
If you notice, VGA only has 15 pins yet the cord is very thick. The reason for this is because of all the shilding around each wire. The farther you go the more the signals are mixed and the final product (at the monitor) becomes more blurry.
Buying a higher end VGA cable is probably the best way to go.
Progress [I will seriously never be done!]
Via EPIA MII
512MB RAM
OEM GPS (embedded)
nLite WinXP pro on
1GB Extreme III CF card
Carnetix 1260 startup/ DC-DC regulator
Software: Still, re-Writing my existing front end in .Net
I'll give it a shot.. I tested with a custom made shielded cat6 cable similiar to the ones I use for my Home theater setup.. They're good for extremely long runs (35 feet is what i'm using).
I made a 5 footer, and it was blurry..
I'll try a high end store bought one..
Right...http://www.mp3car.com/store/product...?products_id=64Originally Posted by Lord_Pall
That's were I just got mine
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
