Results 1 to 2 of 2
Thread: Simple Wiring Question
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    I have two 7" monitors, non-VGA that I need to power. They each want 12v / 1.2A. I want to wire them directly into a cigarette lighter socket so it will feed both.
    Should I put a fuse on the line? I'm assuming so, and if so is it best before or after the split to the monitors, fuse them as one or individually? And well, what size fuses to use, a little higher than load? 1.5A if two, 3A if only one?
    Chris.
    *not an electicial expert*
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    First of i wouldn't run your 7" monitors off the cig lighter without some sort of 12v regulator.
    It isn't really necesary to put a fuse inline but if it will make you feel better. I would put 1 5a fuse before the split. That should be sufficient
  1. Noob Opus wiring question..
    By kuwupt in forum Power Supplies
    Last Post: 11-01-2004, 02:21 AM
  2. Wiring question
    By barometer in forum Newbie
    Last Post: 07-14-2004, 06:35 PM
  3. wiring question about the opus 90w
    By DSM97RS in forum Power Supplies
    Last Post: 03-28-2004, 09:28 PM
  4. wiring question?
    By lopan in forum Power Supplies
    Last Post: 01-07-2004, 09:38 PM
  5. Simple idea, simple question....
    By cruzc_99 in forum Power Supplies
    Last Post: 09-17-2001, 02:35 AM
