Results 1 to 4 of 4
Thread: touch screen help
    Dec 2003
    touch screen help
    i know this has been covered but usually the right side dies on the lilliput panel mine it the entire part. Just help me out and let me know if it is the panel or the controller. I just cleaned it with a surface cleaning pad and it has started to act up
    i need just the touch screen since i think the panel is gone bad. It was acting up and when i pressed in a certain area it would be about 3 inches off. Now anywhere i press all it does it click in the left hand bottom corner. I calibrated like 5 times even the 16 point and it would calibrate just fine but would never work after that properly. well now it aint working at all. please help me
    Dec 2003
    i have been searching around and i dont think it is the part where the right side of the screen might be going out since the left is where the mouse is stuck at, could it be that there is pressure on the left bottom corner so that is why the mouse is stuck there?
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    check there might be a drop of water or something under the touchpad between the screen sometimes that **** messes it up cuz its supposed to kind of float above the screen and wen u touch it it goes down a bit might be pinched on the sides take it to a electronic repair shop man they might be able to look @ it but just a hint wen u put it back together if u open it make sure u dont touch n e 2 pieces of metel hehe i had the bad luck with frying mine :-D
    Dec 2003
    alright guys since i couldnt get any replies i ask god (armen) he told me to do some stuff and well guess what it is a bad touch panel and he will send me one for 45 dollars shipped including a one year warranty so that i a killer deal. right now i am using mouse and keyboard, WOW is the screen beautiful without the touch panel. I am thinking about keeping it.
    Thanks mp3car and armen
  1. Lilliput 7" touch screen can't connect via USB
    By RedBear in forum LCD/Display
    Last Post: 08-26-2006, 07:15 PM
  2. Wide Screen format touch screen
    By belezeebub in forum LCD/Display
    Last Post: 03-22-2005, 11:35 PM
  3. Replies: 4
    Last Post: 09-01-2004, 02:02 AM
  4. the best touch screen
    By EPIK in forum LCD/Display
    Last Post: 01-11-2004, 04:59 PM
  5. wtb:5.6 touch screen w/controller
    By pogue1000 in forum Classified Archive
    Last Post: 11-24-2003, 02:32 PM
