I think the Xenarc on-screen menu may have an "autofit" or "autoadjust" option. good luck.
I just installed my carputer, and got the xenarc hooked up. I have the resoultion set to 800x600. Instead of stretching to the screen, it extends past the border, and I can see a portion. Any ideas on how I can stretch it?
Is the picture pixel-clear or still skewed in addition to losing desktop space?
BIOSTAR M7NCG400 : AMD-M ATHLON XP 2400+ : VANTEC AIRFLOW : 512 MB 3200 RAM : XENARC 700TSVB : MSI 128MB DDR MX4000 : MONSTER 300 WATT INVERTER
it looks clear
Very good chance you can get 800X480 out of that GPU, IF Nvidia use the applet to add the custom resolution, if not get powerstrip but use timing found on Xenarc FAQOriginally Posted by Bama5150
What GPU are you using?
im using the m10000. Its weird, the lilliput was detecting the 800x600 as 800x480. All other modes available to me would stretch (1024x768). When i switched it from 800x600 @60hz to 800x600@75hz it streched fine.
When this happened to my Xenarc, it would cut off the bottom 120 rows of pixels. The built-in resize function didn't correct it either. Adjust your refresh to get the display to correctly detect 800x600.Originally Posted by Bama5150
yep thats what happened and thats what i did. if you were only around yesterday![]()
