You're story is identical to mine! I've been doing fabrication over the holiday and ended up with a dead Lilli this evening. I found the problem at the small ribbon cable where is plugs into the circuit board with the power and control buttons. Make sure the cable is clean, then install it all the way to one side of the connector. If the red LED doesn't light when you power it up, disconnect the cable and move it all the way to the other side of the connector. I even had my blue LEDs blinking when I powered up, that's how bad my situation was. The connector will F#$% with your mind as the internal terminals are in line with the indentions on top of the housing. I was using those indentions to align the GAPS on the ribbon cable. So practically every time, I had the cable perfectly installed BETWEEN the terminals!
LinkBack URL
About LinkBacks
