Results 1 to 6 of 6
Thread: Replace touchscreen on Xenarc/Lili?
    Maximum Bitrate knubile's Avatar
    I haven't found any mention of this in other threads.
    I read in another thread, somebody took the touchscreen out of their Xenarc and that the screen underneath was actually very bright and clear. The touchscreen was the problem for glare.
    I'm sure it'll be possible to replace the touchscreen with a better quality one. I've seen various solutions from 3M and elo. I haven't found a 7" widescreen solution yet, but I'm wonder if anyone here is knowledgable in touchscreen overlays.
    I know there is capacitive and resistive touchscreens. What does the Xenarc use? Is it possible to replace the plastic overlay with one that is more of a film, like the ones you see on in-dash dvd players?
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I am not sure what the xenarc uses but the lilliputs are resistive, I was under the impression that the capacitive touchscreens were the kind that are sprayed onto crt monitors giving the look that it's not touchscreen at all.
    But I dont see any reason why you couldnt change the touchscreen as long as you replaced the controller. It's actually a a good idea I will talk to a friend of mine that works for a company that makes them to see if a custom one can be made that reduces glare.
    肚子笑痛了
    S60 Install
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Yes, the touchscreen dulls the screen majorly. It really makes a huge difference when you remove, it adds about 100 nits.
    I don't know if you'll be able to find any replacements. The ELO touchscreen I have uses the same exact touchscreen glass as well as teh same touchscreen controller, they appear to be the same exact hardware. Lilliputs and xenarc's also use remarkably similar touchscreen hardware. I doubt you'll find anything better in a 7" format then what you have already. The best touchscreen technology I've heard of uses infrared beams to sense where your finger is, the means you don't have any overlay over the screen, but I have yet to see these for sale anywhere. I think cost was prohibitive for the limited market for them.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    3M make capacitive resistive touch screens: http://www.3m.com/3MTouchSystems/Pro...ClearTek.jhtml
    Their version appears to be on a sheet of glass. The glass looks clear in the photograph, but who knows? The main advantage seems to be durability and they are unaffected by dust and contaminants.
    I had a 300nit screen that was pretty usable in the car until I put a touch screen on top of it. It was really dim and the glare was incredible. I've switched to a Xenarc 8". I took it apart last night and it uses a 4 wire resistive touch screen, like the Lilli's.
    Want to:
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Yeh, but the Xenarc's touchscreen dosn't melt because of the heat and break.
    Low Bitrate CherokeeChief's Avatar
    Nov 2004
    Italy
    Hi... I have a 7" LCD Touchscreen from dynamix.... Changing the USB cable, I broken the controller. It is the same in the previous picture...anyone knows were I can buy it as spare part? Thanks!
  1. Replies: 4
    Last Post: 10-13-2004, 10:17 AM
  2. USB Touchscreen Problem
    By skeeter007 in forum Input Devices
    Last Post: 10-07-2004, 03:49 PM
  3. 7" Lilliput for sale NO TOUCHSCREEN
    By CDesigns in forum Classified Archive
    Last Post: 05-24-2004, 10:47 PM
  4. Lilliput touchscreen problem
    By samc in forum Input Devices
    Last Post: 05-09-2004, 12:12 PM
  5. Whats easier? Touchscreen or not to touchscreen?
    By jodathmorr in forum General Hardware Discussion
    Last Post: 10-21-2003, 12:22 AM
