Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Digitalww - replacement TS
  1. #11
    Aug 2004
    well in my current install, the tft was in the original case, all screwed together, but i have since bondo'd the front of the screen into the double din to give it a nicer finish, and am planning on putting a couple of spaces between the front and back of case (since wires are more than long enough for a 5-10mm gap, and then getting a fan on there somewhere, fingers crossed this will solve my issues, as far as summer goes, maybe a timer circuit to turn the fan on for a 10 mins every hour? 30 mins? to keep air flowing, not sure how effective that would be tho.
    MII10000; 512MB RAM; 7" Lilliput Touchscreen; 400watt Muttant AMP; Wireless pc start (keyfob); WiFi; GPS with D3 NM Front End; MediaCar; 40gig 3.5" HD; In-Dash mounted tft;
  2. #12
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    you'd need cold air if the car is parked... while in motion, you use the ac anywho, so the fan blowing to the inside ain't a bad idea. I also recommend a fan to the back. that is going thru the case of the lilli, sionce you gonna have it apart... my 2 cents...
  3. #13
    Aug 2004
    Yeah that is what I was planning on if I can find a fan to fit....shouldnt be too hard hopefully, infact the fan off my MII10000 CPU would do nicely for the job!
  1. DigitalWW Lilliput Touchscreen Replacement
    By archimense in forum LCD/Display
    Last Post: 12-15-2004, 03:17 PM
  2. Directed to DIGITALWW
    By DragonStar in forum LCD/Display
    Last Post: 04-15-2004, 12:57 AM
  3. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  4. Just got my TM-701L from digitalww!
    By Ninja in forum LCD/Display
    Last Post: 12-08-2003, 11:32 PM
  5. DigitalWW LCD Screens
    By edmcgee in forum LCD/Display
    Last Post: 09-26-2003, 12:18 AM
