Results 1 to 10 of 13
Thread: Digitalww - replacement TS
    Aug 2004
    Newcastle UK
    Digitalww - replacement TS better than lilliputs??
    Anyone bought a replacement TS off DigitalWW, mine on my lilli went kaput and I have ordered a replacement, just wondering if i can expect to get the same issues with this replacement (ie calibration screwing up on right hand side?)
    Ps anyone know when these are gonna be back in stock??
    MII10000; 512MB RAM; 7" Lilliput Touchscreen; 400watt Muttant AMP; Wireless pc start (keyfob); WiFi; GPS with D3 NM Front End; MediaCar; 40gig 3.5" HD; In-Dash mounted tft;
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    i bought one of the a couple monts back... it fixes the problem, but if it's in excessive heat (ie. left in the car under the sun) eventually after some time, it will start doing it again. You have to be carefull on where you put the screen.
    cheers
    Aug 2004
    Newcastle UK
    the car I have has a folding down flap over the double DIN (where the tft is installed) so heat shouldnt be an issue, and considering average temperature here at the minute is about 6deg C i don't see it being an external heat issue, you think installing a 80mm fan behind the display is worthwhile to keep air flowing?
    _
    Mar 2004
    Little Elm, Texas
    putting a cover over the screen isn't going to change the fact that in the summer it can get to over 130 degrees F in your car....even in colder climates it can get to well over 100 in the car....no cover will ever change that.....
    no matter what the temperature at the minute...it's constantly changing...it's not going the be winter time year round....
    a fan can never hurt though
    Jan Bennett
    Aug 2004
    Newcastle UK
    i'm guess by this comment you've never been to England......
    _
    Mar 2004
    Little Elm, Texas
    it's not going to be SNOWING year round......
    Jan Bennett
    Aug 2004
    Newcastle UK
    We don't get much of that either tho...just crappy rain and coldness.....seriously tho, you reckon a nice fan at the rear of the display to keep air moving will help stop this occuring, since the tft was only in the car 4 days before it died
    _
    Mar 2004
    Little Elm, Texas
    a fan can never hurt.....=]
    Jan Bennett
    Maximum Bitrate Skipjacks's Avatar
    Dec 2004
    Baltimore, Maryland
    I put a fan under my screen that pulls excessive heat from behind the screan and blows it out into the car. It's a little 45mm fan that does a great job of creating an airflow, but it will have no effectiveness at all come July when the car is parked outside all day. That's a problem I don't know how to address.
    Registered User Dudes99's Avatar
    Dec 2004
    Norfolk, Va
    Skipjacks/RED, I know what you are talking about with interior heat. By no way will my interior get as hot as you'rs down in Texas but 110-120 is still quite hot, though not enough to damage the electronics UNLESS it is in the direct sunlight. Anyone have any thoughts on reversing the polarity on a DC fan? i.e. blow cold AC'd air into the area behind the TS? I don't have a lilli yet, so I don't know, but is there a place to put a heat sink at on the back side of the screen?
    Just my $.02
  1. DigitalWW Lilliput Touchscreen Replacement
    By archimense in forum LCD/Display
    Last Post: 12-15-2004, 03:17 PM
  2. Directed to DIGITALWW
    By DragonStar in forum LCD/Display
    Last Post: 04-15-2004, 12:57 AM
  3. Replies: 2
    Last Post: 12-11-2003, 11:36 PM
  4. Just got my TM-701L from digitalww!
    By Ninja in forum LCD/Display
    Last Post: 12-08-2003, 11:32 PM
  5. DigitalWW LCD Screens
    By edmcgee in forum LCD/Display
    Last Post: 09-26-2003, 12:18 AM
