Results 1 to 10 of 18
Thread: Lilliput can't survive a bump anymore!!!
    Newbie Rover_Eli's Avatar
    Jan 2004
    Florida
    I have a 7" Touchscreen Lilliput mounted on a hinge in front of my AC controls. All of a sudden, every time I hit the slightest bump in the road (which is often since my Land Rover is not the smoothest ride), the Lilliput flickers and starts ghosting with black and white. Hitting the power button has no effect, you have to actually wait until the ghosting stops and then you can power off then power back on. I drove from TN to FL yesterday (~10 hours), and honestly I had view of the screen for a total of about 10 minutes. So needless to say, I about chucked it out the window.
    Has anyone had a similar experience to this?
    Aug 2004
    mini DIN connector ground loose? not sure why a bump would make that much difference to a felxable bit of wire but worth a look, also maybe vga ribbon cable isn't seated correctly, you ever had it apart?
    MII10000; 512MB RAM; 7" Lilliput Touchscreen; 400watt Muttant AMP; Wireless pc start (keyfob); WiFi; GPS with D3 NM Front End; MediaCar; 40gig 3.5" HD; In-Dash mounted tft;
    Jan 2004
    Florida
    Tried the DIN connector
    It's definitely not the DIN connector..
    I've never had it apart. It's like super sensitive right now, I mean it will sometimes do the ghosting/reboot thing even when I try to touch an icon with decent force on the touchscreen.
    Aug 2004
    I really don't know then - I've got my lilli in bits at the moment the TS has gone, i did notice that if the ribbon cable to the control board (on/off button etc) was not seated properly it gave strange results...
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    I would suspect you have something that if not properly soldered anymore and gets grounded on a sporadic base... but I am no liliput owner, so I cannot say.
    does anyone else have this - I am gettig nervous about getting a lilliput and start to think the xenarc's extra buck would be worthed.
    -Mars
    Nov 2004
    NY tri-state
    I had the exact same problem with mine... it's the ribbon cable going to the board (not the screen). Powered up and half-open, if you press to "sit" the cable flush the screen looks perfect. The slightest movement (such as when closing the screen) or pressure on the TS would create ghosting, weird colors, etc.
    Easily fixed by securing the ribbon cable to the board at the clip with a couple of pieces of electrical tape. It's probably overkill, but the little BS clip that holds the ribbon in place seems kinda finicky to me, so I made sure the cable wasn't gonna move..
    Works like a charm since I did it. And there's still enough slack on the whole thing should I ever need to move the screen around (to get to the screws or something).
    Jan 2004
    Florida
    Thanks a million- I'll try checking this out when I get home, and I'll re-post to let you know how it pans out.
    Jan 2004
    Florida
    Angry Crap
    So I took it apart, taped the connector down, and still no luck. I filmed a movie real quick to show you all what happens:
    I tap it just to show the light effects of what happens with a bump:
    VIDEO LINK - BAD LILLIPUT
    Any other ideas??? I am running out of my own here...
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    oh wow thats crazy, ya need an exorcist.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    Nov 2004
    NY tri-state
    Quote Originally Posted by Rover_Eli
    I saw the video and this is exactly, EXACTLY what was happening to mine -- just over the weekend. I had taken it apart to try and see how I was gonna fit it in the dash (still working on that ) and something obviously went wrong...
    Now I don't know why yours is doing that if you never took it apart (did you buy it used?) but my guess is that if you take both ribbon connectors off and re-align them, and make sure they're seating properly, it will fix the issue. Mine was doing that exact same thing, and when I opened it partially (yes, with power and signal, I'm hardcore like that ) and fiddled with the connectors I found that touching the cable to the board would fix it... as soon as I lifted my finger it went back to the craziness.
    Now your mileage will obviously vary, and if you bork yours even more you're on your own, of course... I'm just telling you what fixed it -- for me.
  1. Replies: 118
    Last Post: 10-22-2010, 04:05 PM
  2. Lilliput touchscreen problems -- Need Help
    By BrUTaL in forum LCD/Display
    Last Post: 08-20-2004, 09:41 PM
  3. help lilliput wont power up anymore
    By heynicecar in forum LCD/Display
    Last Post: 05-31-2004, 06:56 PM
  4. Lilliput USB not recognized anymore
    By SFiorito in forum LCD/Display
    Last Post: 05-31-2004, 12:09 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
