Results 1 to 10 of 14
Thread: power for the Lilliput
    Nov 2004
    San Diego & Fort Hood, Texas
    How do you all power your displays? I don't want to run it to my cigarette lighter. I don't smoke, l I just don't think it would look good. Can I cut off the end of the cigarette lighter adapter and run it to a 12V source?
    I plan to have a switch for power to my carputer, so if it's not a problem having a switch for the monitor as well; I'll run them to the same switch.
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    Yes thats what I do. Just cut it off and run it to a hot wire or a switched ignition source. And ground the other end.
    What will the switch for your computer shut off? Do you have an Opus or something? As long as whatever you are switching with the switch is 12 volts then yes, you can use the same switch. If there different voltages, you'll have to use a 2 relays and a switch to control the 2 different voltages.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Nov 2004
    The switch will be dedicated for just the carputer, using a cartnetix unit. I'll either tap the power from the cigarette lighter or run it from the terminal. I just noticed though that the adapter is a 12v adapter. Do I even need the egg or can I just run power to it?
    Oct 2004
    I've heard that the egg regulates the power. But they also say that it causes problems. I have a dedicated battery for the carputer so I wont need a regulator but if you don't you may need the regulator for power surges such as when you turn on your headlights. Anyone else?
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
    Nov 2004
    Yeah, it seems to be a regulator. I guess I'll keep the egg.
    Oct 2004
    If you don't have another regulator between the lilli it will fry eventually, when you start your engine you will be putting ~14.8V on your lilli instead of 12. Soon your lcd backlight will be smokin..(this is why the lights get brighter after you started the engine)
    The egg on the lilli is of very poor quality. It makes a buzz on your audioset. And a very small chance it dies an takes the lilli with it.
    So put in a dedicated battery/ connect the lilli without egg to the psu /or just leave it as it is.
    Nov 2004
    Quote Originally Posted by Skeeter
    OK, would this regulator work?
    There's a constant noise from the egg, it bothers me.
    Nov 2004
    Granted I am aware of some of some of the shody-work Lilliput has done putting together their 7" touchscreens... but I have my LCD hooked directly to the "egg" which is hard-wired to constant power.
    Then my computer turns on and wakes it from stand-by. There is NO 'hum' from it and I'm sure it might not be the best regulator but a regulator is pretty much a regulator and I'm sure if you "crack the egg" open you'd see a regulator much similar to the one pictured above. So I think it's fine to do this.
    Here's a question though... has anyone ever hooked an ammeter up to the lilliput to see how much current it draws in standby mode? I'm sure it's just a few milliamps which is fine... anyone know for sure?
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i dont understand why the lcd wouldnt have that built into the pcb
    PC Components:
    My work log
    Self proclaimed spoon feeder TruckinMP3's Avatar
    Jun 2002
    Colorado
    What power supply are you using?
    Can it handle the draw of the screen?
    If it can handle the draw and has a regulated 12v rail you can cut up a PC molex connector from a PC fan and use it to connect the LCD power to the PC PS (yellow and Black wires for 12v)
    I do this for my 14 inch LCD it works great. The LCD turns on/off with the PS.
    TruckinMP3
    Read the FAQ!
  1. 12v Power Supply at MP3Car.com store
    By mykolJay in forum Power Supplies
    Last Post: 02-02-2006, 10:17 PM
  2. alternative power adaptor for Lilliput??
    By PHiLiSO in forum LCD/Display
    Last Post: 10-04-2004, 08:10 PM
  3. Lilliput Power Polarity?
    By aleromaster in forum LCD/Display
    Last Post: 09-10-2004, 03:22 PM
  4. Possible to power lilliput this way?
    By ScorpionV in forum LCD/Display
    Last Post: 07-19-2004, 08:39 AM
  5. Opus power supply issue
    By dmazyn in forum Power Supplies
    Last Post: 10-15-2003, 07:32 PM
