Page 2 of 6 FirstFirst 123456 LastLast
Results 11 to 20 of 55
Thread: Successful LVDS LCD installations?
  1. #11
    Feb 2004
    Quote Originally Posted by Yuriy
    Hehe, well, I got lucky and actually extended my laptop cable to about 2 meters (6 feet).
    Works great with just a little interference (barely noticable).
    That's some good info though, the LVDS sure sound like an option. You'd need pinouts and connectors tho, as I would guess..
    Got the pinouts, and they're fairly simple.
    Power, Signal A+, Signal A-, (and B+/-, and C+/-), grounds, and Signal Clock +/-, that's pretty much it.. maybe 16-17 connected pins out of 20, on the LCD side.
    The connectors I got, too, except they're almost the right kind.
    I posted a picture here - they're tiny:
    http://www.mp3car.com/vbulletin/show...4&postcount=22
  2. #12
    Feb 2004
    Pinouts
    Here's an example of the LVDS pinouts required for the motherboard (Commell LV-671) and LCD (EVD084S01-DT from eVisiondisplays.com, aka AUO B084SN01 w/enhancements) that I have chosen for my WRX CarPC project.
    The document shows three things:
    1. The LCD Type number table, used to set the LCD Type in the BIOS.
    2. The LVDS connector pinouts on the motherboard.
    3. The LVDS pinouts on the LCD panel.
    The LCD I chose is an 18-bit panel at 800x600, and is a single-channel model, so the appropriate LCD Type setting in the BIOS would be number 2, which is highlighted in Bold.
    If the LCD was different, I would have to pick a different type, such as a 1024x768 24-bit Single Channel panel - the appropriate LCD Type would be 8.
    What's the difference between an 18-bit panel and a 24-bit panel?
    An 18-bit panel can display about 262K colors, and a 24-bit panel can display 16 Million. Most smaller LVDS LCD panels will only be 18-bit, as most 24-bit panels are larger and have a higher resolution.
    For the 18-bit 800x600 single-channel LCD I chose, the pins I would need to connect to on the motherboard are highlighted in bold - there are a total of 18 pins, to match the 18 of 20 pins on the LCD panel connector.
    The LVDS data is transmitted on the ATX0-2 +/- pairs, and each pair carries 6-bit's worth of data, so for an 18-bit single-channel panel, I would need to use the first three ATX pairs. For a 24-bit single-channel, I would need to use the first 4 ATX pairs.
    You may notice similar pairs named BTX0-3 - those are for the 2nd channel, if you needed a dual-channel connection. For an 18-bit dual-channel, you would use ATX0-2 (3 pairs), and BTX0-2 (3 pairs). For 24-bit dual-channel, you would use ATX0-3 (4 pairs) and BTX0-3 (4 pairs).
    The transmitted data is kept in sync by the ATXCK (clock) pairs - for a dual channel LCD, you would use both clocks, and possibly the PANELCLK and PANELDATA pins.
    One remaining thing I have to verify is the polarity of the +/- pairs.
    That is, whether the - on one end goes to the + on the other, or whether it's a same-to-same connection, like - to - and + to +.
    I think it's same-to-same, but I have to verify that.
    Attached Files Attached Files
  3. #13
    Feb 2004
    Actually, this had me thinking...
    Do you know what the model number of the LCD panel is?
    And what kind of cabling/wire did you use?
    There's a possibility that your LCD panel is LVDS.. and if you extended it to 6 feet with little interference, that's a good sign.
  4. #14
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    Quote Originally Posted by Giuliano
    The LCD is Toshiba LTM12C263, it came with the Compaq LTE 5300 laptop (all 5xxx series have the same connectors except for 5250). As me and Oracle later found out, this screeen is actually a widely used one and is used on a lot of Compaq laptops (such as the Armada) and possible some (if not all) Toshiba models.
    I do not have the pinout, but it's approximately 24 pins in a row (similar to the ones you have) on the LCD side and 2 rows of approx. 12 pins on the motherboard side. But! The same LCD used on the Armada laptop only has about 6-8 wires (excluding the inverter) that connect it to the motherboard!
    Oh yeah, the one in the Armada is a slightly different LCD with the LTM12C283 and it has a resolution of 1024x768 instead of 800x600 that my LCDs have. The connectors that go into the LCD itself are exactly the same.
    http://www.mp3car.com/vbulletin/atta...achmentid=3462
    One more thing I noticed is that when you connect an LCD with a lower resolution (I have some with 640x480) to a laptop that outputs 800x600 you will still get the image but it will be moved 160 pixels to the right and 120 down, just like the black "frame" you always seem to notice around higher resolution screens running at lower res then native. The image was chopped off but otherwise was pretty clear. I bet it could be fixed with the right software.
    Anyway, you got me thinking too, seems like we are one step closer to connecting a laptop LCD to a PC
    I am thinking about sending you one of my LCDs and see if you can connect it, and then if you succeed we would all benefit from it
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
  5. #15
    Jun 2004
    Seattle
    Oh, I used the printer cable to extend it. The most recent extension I made was a bit shorter (about 3 feet) with no interference. As I found out later the interference I had previously was caused by some wires occasionally touching each other. One common problem that all my extensions experience is the inability to display resolutions lower than native. But once Windows kicks in it all displays fine. The current extension I'm using displays all resolutions because each wire is independently wrapped and carefully connected.
  6. #16
    Feb 2004
    This LCD model is not LVDS, but TTL/CMOS - I'm amazed you managed to get a good signal with a cable that long, as everything I've read has indicated otherwise.
    Pinouts found here:
    http://physio.phys.szote.u-szeged.hu.../ltm12c263.htm
    The first two columns show the pins for the LCD-side connector.
    The signals R0-R5, G0-G5, and B0-B5 indicate that this is a 18-bit (6+6+6) TTL/CMOS panel.
    The specs linked above for the *63 LCD say 30 pins, so ~26 pins might be right..
    I have a few thoughts on that - it might be solved with using only the Least Significant Bits of each channel, like R0-R4 instead of R0-R5, for example, but I think that has more to do with color depth.. maybe..
    Got any part numbers for those 640x480 LCD's?
    I'll see if I can find specs and take a look..
    Sure!
    PM or e-mail me a list of the LCD's you've got, and part numbers, and we'll see.
    I do have an old Compaq Presario laptop with a perfectly working LCD, so I'll see if I can dig that out and check the specs on it.. I think it's a 14.1", but if it's LVDS, it'll be good for testing.
    In any case, I probably won't have my motherboard for another month or two, depending on my free spending cash at the time..
  7. #17
    Maximum Bitrate Hcomplyr's Avatar
    Nov 2003
    Salem MA USA
    i have an old prostar laptop (celeron 400) with a 12.1" LCD i think i have to try this :-D
    500Mhz Celeron, 256MB RAM, 20GB Hard drive, Sound Blaster MP3 USB
    Installing in Monte
    1994 Ford Probe SE beater/Girlfriend's car
    1995 Monte Carlo Z34 Engineless carPC
  8. #18
    Jun 2004
    Seattle
    I beleive the other 10.1" LCD is the LTM-09C015-1 640 X 480
    http://physio.phys.szote.u-szeged.hu...UTS.HTM#09c015
    I don't have the labels on it but it fits the pattern. It's currently in my friend's car.
    By the way, it has different connectors on the back than the 800x600 ones and even though it has the same motherboard connector it won't show any image with the never processors. By that I mean, if you plug in an older processor the image will be there, but if you plug in a processor that is designed to work with 800x600 LCDs (later laptops) it will just be blank. By processor I mean the board that holds the CPU, RAM and the CMOS chip on that particular model of the laptop. It seems like every part of those laptops is backwards compatible except the CPUs and the LCDs.
    I can send you the 800x600 panel, although I'll have to look if I have any spare ones for backup since I'll be installing a second carputer in my car soon.
  9. #19
    Jun 2004
    Seattle
    That only happens if the resolution is set to lower than 800x600. Once the native kicks in the image is not moved but chopped off because the smaller LCD only displays the first 640x480 pixels
  10. #20
    Maximum Bitrate knubile's Avatar
    Have any of you managed to find an LCD comparable to the Xenarc at a reasonable price? 7" 800x600.
  1. 8.4" LCD in WRX dash.
    By Giuliano in forum LCD/Display
    Last Post: 08-07-2010, 04:27 AM
  2. Possible 8.4" LVDS 1024x768 LCD?
    Last Post: 03-24-2004, 10:02 PM
  3. any successful E36 installations ?
    By ccblanket in forum Newbie
    Last Post: 10-03-2003, 05:28 PM
  4. LVDS lcd controller
    By ddogg_777 in forum LCD/Display
    Last Post: 04-10-2003, 10:01 PM
  5. LVDS laptop lcd
    By ToxicBunny in forum LCD/Display
    Last Post: 07-18-2002, 06:02 PM
