Page 4 of 6 FirstFirst 123456 LastLast
Results 31 to 40 of 55
Thread: Successful LVDS LCD installations?
  1. #31
    Jun 2005
    Ah ok. I think I've got it now. Waiting for the motherboard to come in now so I can check out where the connections are. Thanks for the help!
  2. #32
    Jun 2005
    LVDS to Motherboard connections - Need to run this by somebody to make sure I have the right idea.
    On the 40 pin LVDS connector on the Commell LV-673 motherboard - It looks like the odd numbered pins are for driving it via single channel(?) so I guess I would wire up that side to the corresponding pins on the LCD.
    Any idea what LVDDCLK and LVDDAT do? I don't see anything that corresponds on the LCD, so I think it'll work fine without those. Only pin I'm missing input from the motherboard for is the scan direction selector, but I guess I'll wait until I see how the LCD is oriented first and then hardwire that to high or low.
    motherboard pinout (sorry for the lack of formatting)
    Pin Signal Pin Signal
    2 LCDVCC 1 LCDVCC
    4 GND 3 GND
    6 ATX0- 5 BTX0-
    8 ATX0+ 7 BTX0+
    10 GND 9 GND
    12 ATX1- 11 BTX1-
    14 ATX1+ 13 BTX1+
    16 GND 15 GND
    18 ATX2- 17 BTX2-
    20 ATX2+ 19 BTX2+
    22 GND 21 GND
    24 ACLK- 23 N/C
    26 ACLK+ 25 N/C
    28 GND 27 GND
    30 N/C 29 BCLK-
    32 N/C 31 BCLK+
    34 GND 33 GND
    36 LVDDCLK 35 N/C
    38 LVDDDAT 37 N/C
    40 N/C 39 N/C
  3. #33
    Constant Bitrate donde's Avatar
    May 2005
    Texas
    I am thinking of getting an lvds panel from evision displays as well (they have up to 700 nit monitors now btw), but I have a couple questions.
    First, what type of cable would I need to use to extend the hirose cable about 6 feet?
    Second, the pinout for my sp13000's lvds connector doesn't really look like the one above.The pinout is in the pdf file in the link below, page 45 of the pdf or page 37 of the actual manual. I can't seem to find a definite resemblence to the pinout above for the three video signals.
    http://www.viaembedded.com/product/3/4/EPIA-SP_v100.pdf
    And if you know where to find the 50 pin connector I need please tell me that too. Thanks
  4. #34
    Jun 2005
    The cables are usually custom wired since the pinouts will differ on both sides of the cable- first, get the appropriate connectors: 1 for the motherboard side and 1 for the lcd side. Then wire it up with some 28 gauge wire and crimp into the connectors. Make sure you twist the signal pair wires.
    The connectors should be listed in the manuals for the LCD and mobo. I didn't see a connector listed in that manual for the motherboard, so you may have to call them for that and to get the description of what each signal code on the table stands for. They don't even have the polarity of the pins listed, so it would be a pain to guess at it, especially while you are trying to make a connector at the same time.
  5. #35
    Constant Bitrate BADDERICK's Avatar
    Jun 2005
    Las Vegas
    Is this possible? I have a single board computersee attached .PDF with lcd and crt support, I have the lvds controller and the 15" touch screen that all came together as an industrial PC. The motherboard has two plugs for the lcd, a 44 pin and a 20 pin connector that go to the lvds board. This PDF gives the pin-outs from the motherboard.
    Now for the question.....Is there any way to convert the 44 and 20 pin connectors from the controller so that I could use the screen with other setups? maybe like a DVI?
    ----- EDIT-------
    The PDF was to big to attach so here is a link.
    http://www.axiomtek.com.tw/Download/Manual/SBC82610.pdf
    2003 100th harley F-150
    PCChips C3 VIA/eden, M1 ATX smart car.
    Here is my project so far: My 100TH Harley-Puter
    Ride safe
    Buy my stuff: Stuff
  6. #36
    Newbie mikeyd's Avatar
    Jul 2005
    I did have a Compaq laptop in my car which I separated the 14.1" LCD from and put it in my dash. It looked great but for the year and a half or so that I had it in there, it was nearly nothing but trouble. Extending the crazy small ribbon cable was a tedious nightmare and I'll never do it again. But I could not find any sort of wire diagram for the LCD in order to connect it to something other than the laptop it was intended for. I'm surprised I made it work but the fragility of the screen and its connections and cables proved to make the use of the screen impractical. The picture was definetely sharper and brighter than the 12" I have now.
    Good times!
  7. #37
    Oct 2004
    NY
    I have an lvds screen working in my car, but I need to add backlighting......guliano, I saw you mention controlling a pwm inverter with a 555 circuit, do you know if this would work on multiple inverters? I'm looking to use 5 dual inverters on 10 ccfl's, but I am hearing all kinds of negative things about a config. like this.....I would apreciate your input....
  8. #38
    Banned
    Jul 2005
    we could offer LVDS TO TTL or TTL to LVDS convert board, if you have interesting in it, please contact me.
    Email: stocklcd@126.com
  9. #39
    Jun 2005
    Las Vegas
    How much would this board be?
    I would be very interested if the price was right.
    Ride safe
    Buy my stuff: Stuff
  10. #40
    Jul 2005
    What about the MSI cards with "Integrated dual LVDS Transmitter supporting LCD panels up to 2048x1536". Can I actually use this instead of going out and buying an expensive controller card?
  1. 8.4" LCD in WRX dash.
    By Giuliano in forum LCD/Display
    Last Post: 08-07-2010, 04:27 AM
  2. Possible 8.4" LVDS 1024x768 LCD?
    Last Post: 03-24-2004, 10:02 PM
  3. any successful E36 installations ?
    By ccblanket in forum Newbie
    Last Post: 10-03-2003, 05:28 PM
  4. LVDS lcd controller
    By ddogg_777 in forum LCD/Display
    Last Post: 04-10-2003, 10:01 PM
  5. LVDS laptop lcd
    By ToxicBunny in forum LCD/Display
    Last Post: 07-18-2002, 06:02 PM
