Page 1 of 6 123456 LastLast
Results 1 to 10 of 55
Thread: Successful LVDS LCD installations?
    Feb 2004
    I searched through ~140 threads in this group to find this answer, but I didn't see it:
    Has anybody here done a successful installation of a LVDS LCD panel?
    I see lots of threads (including my own) about motherboards with LVDS onboard, and various LCD's that may or may not be LVDS, but no actual installations.
    I've been planning on going the LVDS route (with a Commell LV-671 board), and I believe I have a reasonably good chance of success due to my understanding of electronics, among other subjects.
    If nobody else has done an LVDS installation, I'll write up a good FAQ about it, once I start my installation.. which may still take another month or two.
    Anybody?
    Jul 2004
    how about more info about LVDS than just the acronym for us dummies here?
    Maximum Bitrate Yuriy's Avatar
    Jun 2004
    Seattle
    LVDS as in laptop LCDs? There have been a lot of laptop installs (including some of my own) but I doubt anyone actually connected something like that to a custom PC, the controller prices are simply horrid.
    00 Saturn SL2, boosted @ 8 psi - CarDomain
    Newest install - my quickest ever
    My 2nd carputer - b4 I broke the touchscreen
    My very first carputer - voted the most ghetto
    Feb 2004
    Quote Originally Posted by Jackboot
    LVDS stands for Low Voltage Differential Signalling, and is one of the two commonly used LCD communication types, with the other being called TTL/CMOS.
    LVDS and TTL/CMOS are most often used in laptops, where a direct digital connection to the LCD is required.
    TTL/CMOS is the more common of the two signalling technologies, but it has some limitations, such as short cable length, and high number of pins/wires, often numbering in the 30-40 pin count.
    As a result, LCD's with TTL/CMOS technologies cannot be very far from their controller, which is why you see LCD's like the Lilliput/Xenarc models with VGA controller boards.
    LCD panels are not like analog glass-tube monitors - LCD's have a native physical resolution, and perform best only at that resolution, such as 640x480 or 800x600, or even the difficult to obtain 800x480 of widescreen LCD's.
    VGA controller boards get around this limit by scaling down (or up) your PC's analog VGA signal to whatever physical resolution the LCD is capable of, which results in a blurry picture.
    In addition, the process of conversion from digital to analog (VGA video port), and then back from analog (VGA LCD controller) back to digital (LCD itself) can lead to signal degredation and a fuzzy picture, because analog transmissions can easily be affected by EMI (electromagnetic interference).
    TTL/CMOS wiring uses 1 wire for each bit of color resolution that the LCD is capable of - so if you have an 18-bit TTL/CMOS LCD capable of 262k colors, you have (at least) 18 wires to transmit signals on, not including power and ground lines, etc.. that many number of wires, and the method of signalling, can cause crosstalk (interference) problems in longer cables.
    Because of this, TTL/CMOS data cables can not be longer than 6 or 12 inches, due to the interference over long lines.
    LVDS solves this by transmitting the three color signals (Red, Green, Blue) on 6 wires, or 3 differential pairs. Because the signal is differential, or the difference between the signal on one wire and another, data can be transmitted farther than TTL/CMOS can, up to 12 meters with proper (shielded?) cabling.
    The reason for LVDS's newfound popularity is simple - there are now Mini-ITX boards on the market that have LVDS transmitters on-board or as an option, and can easily drive the proper LCD's with the right cabling and knowledge.
    Previously, in order to use a TTL/CMOS or LVDS LCD panel, you either had to have a VGA controller card attached to the LCD, a PCI LCD controller card attached to the PC, or you had to purchase a special "embedded" type of motherboard, usually in non-PC form factors such as PC/104 or boards the shape and size of a 5 1/4" drive.
    Quote Originally Posted by Yuriy
    See, that's the point - you can now buy MiniITX motherboards with LVDS controllers built in (such as the Commell LV-670/671 P4 series), or as an option board (some Via Epia models).
    The motherboards take care of all the LCD specific timing issues, and backlighting control, making it easier to use LCDs with these boards.
    However, it won't work with just any LVDS LCD panel - the LCD panel has to support a specific resolution, color depth, and channeling (single/dual) such as 800x600 18-bit Single Channel, or 1280x1024 24-bit Dual Channel, and the video timing parameters for those LCD types must be supported by the motherboard's system bios for them to work.
    This is why non-standard LCD sizes, such as the ever popular 7" widescreen 800x480 LCD's are not currently easily supported - it's because the motherboard manufacturers have not tested them and included the timing parameter set in their bios.
    And that's even assuming you can locate and purchase a 7" widescreen LVDS panel - I've tried, and I can locate them easily enough, but it's next to impossible to buy one from a retailer or distributor, unless you want to buy tens of thousands at once.
    The easy availability and standard resolution support of 4:3 aspect ratio LVDS LCDs make the possibility of an all-digital display solution that much more appealing, which is why I'm working on fitting a 8.4" 4:3 high-resolution screen in my WRX instead of a 7" widescreen Liliput or Xenarc.
    Dec 2003
    Well put
    There was a previous post with tons of sites in the east( korea, china) they seem to love lvds and have successfully used it. Lvds is the future, but I think we have a way to go before it reaches us. The site I mentioned also sold kits and the prices seemed reasonable, but ordering overseas and language barrier can seriously hamper things.
    Pete
    Jul 2004
    well written Giuliano. Makes sense to me now...
    ...unfortunately, I think there will be few here that have the technical knowledge to help you much. Best of luck though!
    My question: is the difference in display quality between VGA and LVDS drastic enough to warrant such effort? Of course, I guess the same could be said concerning our efforts to install an entire PC in our cars rather than go buy an AVIC-N1 or similar...
    Maximum Bitrate DeltaFX's Avatar
    France
    Lvds is the key if you need to create a laptop/tablet-like pc. For a car-puter, using lvds is ... well an exercise of style.
    Feb 2004
    I think I've got what it takes in technical skills to pull it off, which is why I'm going forward with my plans for an 8.4" LVDS LCD.
    The upshot is that by hand-picking specific models of LVDS lcd's, you can pick and choose what resolutions and brightness you will accept, as opposed to having to pick from what the retail LCD market offers.
    Right now, I am planning on getting an 8.4" LVDS LCD that has a native resolution of 800x600 - most small size LCDs on the market today cannot do this, even if the back of the case says 800x600 or 1024x768.
    Those stated resolutions are what the VGA controller is able to accept, it simply scales the resolution up/down to fit the physical panel resolution.
    Right now, I also have the option of buying an 8.4" LCD that does 1024x768 - except it's too big to fit in my WRX's dash right now, without having to do some additional major modifications. I'm sure I will get it later, in "Rev 2" of my system.
    So the upshot of going the LVDS route is that you can pick from small-size LCDs that have higher native resolutions, resulting in a sharper and clearer picture.
    The fact that it's digital as opposed to analog is also a benefit, because there is less A/D conversion going on, and less signal loss in the process.
    Feb 2004
    Quote Originally Posted by DeltaFX
    Good point..
    Can you do a CarPC without a bare LCD, LVDS or not?
    Sure you can..
    But I've always believed in doing things with style.
    Jun 2004
    Seattle
    Hehe, well, I got lucky and actually extended my laptop cable to about 2 meters (6 feet).
    Works great with just a little interference (barely noticable).
    That's some good info though, the LVDS sure sound like an option. You'd need pinouts and connectors tho, as I would guess..
  1. 8.4" LCD in WRX dash.
    By Giuliano in forum LCD/Display
    Last Post: 08-07-2010, 04:27 AM
  2. Possible 8.4" LVDS 1024x768 LCD?
    Last Post: 03-24-2004, 10:02 PM
  3. any successful E36 installations ?
    By ccblanket in forum Newbie
    Last Post: 10-03-2003, 05:28 PM
  4. LVDS lcd controller
    By ddogg_777 in forum LCD/Display
    Last Post: 04-10-2003, 10:01 PM
  5. LVDS laptop lcd
    By ToxicBunny in forum LCD/Display
    Last Post: 07-18-2002, 06:02 PM
