Results 1 to 10 of 15
Thread: Ultra Thin VGA cable
    Maximum Bitrate brrman's Avatar
    Aug 2003
    Indianapolis, IN USA
    Not sure if anyone has posted on this before...
    But I am having trouble with the install of my carputer behind my screen (VERY tight space and the VGA plug is too damned big) the screen wont clip back in all the way into the dash cuz the plug is in the way.
    After searching I have found the answer...
    http://www.bestbuycable.com/search_v...asp?txtFrom=SP
    This makes my frigging day! I was all set to go hacking up my Xenarc screen cable.
    Car: 2000 Audi A4 Avant 1.8t
    Carputer 2.0: removed. Back to stock.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    sorted!!! nice find.
    Super Moderator xBrady's Avatar
    USA
    Doesn't ultrathin also mean ultra-unshielded. Thus you get ultra-interference?
    Installed.
    -GPSSecure- - GPS Tracking
    Mar 2004
    Bristol
    wrap it in ally foil
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    They make it sound good but the only way to know for sure is to try it. Ultimately if you're making a short run and using lower resolutions and refresh rates typical of 7" LCD, you're unlikely to encounter much ghosting.
    Newbie After_Forever's Avatar
    Nov 2004
    They look just like the cables I have purchased from L-COM.com in the past. I use them for work by cutting off one end and wiring it unto another connector. They are shielded on the inside with foil and have three small coax cables for the Red, Green, and Blue signals. Never had a problem with noise interference………… However the price is WAY different!
    $40 for one cable assembly
    http://www.l-com.com/jump.jsp?lGen=p...iProductID=208
    1996 Suburban
    4- 5” headrest TV monitors
    1- 7” touch display for driver
    3GHz computer w/ 2 video cards
    1 video for the 4 monitor 2nd video for the driver
    2 sound cards
    1 sound for the 4 monitors 2nd sound for the driver
    2 XBOXs
    2% done
    Aug 2003
    if you actually read the info on the cable - its triple shielded
    "UltraThin VGA/SVGA HD15 Male to Female Triple Shielded Flexible Extension Cable "
    in any case - I have one on the way so I'll see how it works out.. for 6 bucks its worth a try
    Variable Bitrate Supermike's Avatar
    May 2004
    AZ
    Thanks for the deal, looks promising, though I don't see a single review for them on resellerratings ( I guess they start off with a 10). Went ahead and ordered a 15 foot'er, since the price is hot and I may need one of these for my project.
    "Protecting Privacy and Free Speech Online"
    http://www.eff.org/
    Variable Bitrate choyak's Avatar
    Jun 2004
    Buena Park, CA
    Yeah that is a hokey name. Isn't it trademark infringement???
    Carputer currently 'ghettoed' into car!!!
    EPIA MII-12000
    Ampie Case with rigged extra USB
    Hitachi 60GB
    Holux GPS mouse with iGuidance 2.0
    Lilliput 7" touchscreen
    Netgear WG121 USB WiFi
    Carnetix P1260
    Aug 2003
    myu cable has shipped already. nice
  1. VGA Cable causing engine noise
    By sq_geek in forum Car Audio
    Last Post: 12-28-2004, 12:47 PM
  2. Fuzzy output using long VGA cable...
    By sq_geek in forum LCD/Display
    Last Post: 06-11-2004, 08:37 AM
  3. Vga to Svideo cable?
    By si2001 in forum LCD/Display
    Last Post: 11-01-2003, 02:33 PM
  4. Mounting my Datalux and VGA cable question
    By gfoulks in forum LCD/Display
    Last Post: 08-26-2002, 12:35 PM
  5. VGA LCD Quality with long VGA cable?
    By vikrampant in forum LCD/Display
    Last Post: 01-11-2002, 01:02 AM
