Results 1 to 3 of 3
Thread: Mounting the Xenarc in the dash
    FLAC edrex's Avatar
    Dec 2004
    West Chestinghamshire, UK init!!
    Question Mounting the Xenarc in the dash
    Ok, got my Xenarc now. () Now I need to know how to mount it in the dash. A search turned up mostly people who were mounting on the dash in different areas. I have a double din factory headunit and want to put the Xenarc in its place. How does the unit stay in place? Will I need extra brackets for mounting it? Are there any write-ups on how to do it?
    Thanks for the help.
    Spent so far: $1,755
    Check Out My Work Log for Specs/Pics
    CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]
    Don't mess with Texas.
    It's not nice to pick on retards!
    Nov 2004
    NY tri-state
    Talk to Altimat. I know his car is a different year, but he should have some good ideas... or do a search for your car. I've seen the Altima dash around here with an LCD in it somewhere around here, so somebody has definitely done it before.
    I've taken apart my Maxima dash a million times already, and I can tell you that there's a LOT of stuff back there where you can mount the screen -- at least in my car. I think most people just fabricate the front of the bezel into the dash, then screw the back into the front and call it a day.
    FLAC alti's Avatar
    NY
    there are Three altima instals that I am aware of in 3ed gen altimas
    Altimat an one of the others installed theres above the radio where you have a cubby i think (mine has the vents there, in 05 they moved the vents to the side of the radio.
    There was another that installed a 6.5 screen (i think) from EarthLCD where the radio is (was)
    Mine when done will also be where the radio is but is a larger 10.4"
    go to the advanced search feature and search the show off your project forum for altima they should all come up. some of the pics no longer work but pm altimat he could likely send you his and the other above the radio install was also done by him.
    hope this helps
    good luck!
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  1. new ssr, xenarc in dash or pull-out?
    By pesos in forum LCD/Display
    Last Post: 01-09-2005, 02:40 PM
  2. Mounting Xenarc inside dash - But removable!
    By Pabs in forum LCD/Display
    Last Post: 09-06-2004, 04:20 PM
  3. Mounting ideas for slimline dvd player in dash
    By psyclobe in forum General Hardware Discussion
    Last Post: 02-11-2004, 11:52 AM
  4. Mounting the LCD inside the dash?
    By XxAndyxX in forum Newbie
    Last Post: 01-16-2004, 04:51 PM
  5. dash mounting
    By smashr2k in forum LCD/Display
    Last Post: 10-23-2002, 12:27 AM
