Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 35
Thread: Anyone care to help me with a mystery screen?
  1. #11
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    yeah those are high voltage lines
    肚子笑痛了
    S60 Install
  2. #12
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    its white(video), black(video), black(ground), red(12v)
    PC Components:
    My work log
  3. #13
    Dec 2004
    Maryland
    obviously my screen is not the same as yours, but those pins are probably pretty much standard. The connector is the same at least
    PC Components:
    My work log
  4. #14
    Dec 2004
    Maryland
    Stupid camera not taking a good picture. But this one is a bit better.
    PC Components:
    My work log
  5. #15
    Newbie Rover_Eli's Avatar
    Jan 2004
    Florida
    So where can I get two connectors like those?
  6. #16
    Jan 2004
    Florida
    Here's the pics you requested as well...
  7. #17
    Jan 2004
    Florida
    Also...
    Can you post a better pic of what the white and black wires are? Are they just RCA inputs?
  8. #18
    Dec 2004
    Maryland
    i'd get them out of a car your friend was selling
    Not sure, i'd just try soldering to the pins, and making your own connectors. Cur the plastic around the pins, and just tin the edges, wouldnt be a hard soldering job.
    PC Components:
    My work log
  9. #19
    Dec 2004
    Maryland
    my camera is ****. But yeah the white and black wires are just RCA.
    PC Components:
    My work log
  10. #20
    May 2003
    Miami, FL
    If you check each pin, and find the one that goes to the black side of that cap thats Labeled 2CS 100 16V that will be your ground and the one next to it should be 12v then all you have to do is attach the other two wires for video
    肚子笑痛了
    S60 Install
  1. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  2. What the....same screen? Good screen?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-31-2004, 12:37 AM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  4. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 06:49 PM
