Page 1 of 4 1234 LastLast
Results 1 to 10 of 35
Thread: Anyone care to help me with a mystery screen?
    Newbie Rover_Eli's Avatar
    Jan 2004
    Florida
    I recently got two headrest monitors from a friend of mine out of a car he was selling, but the problem is, neither of us can find any of the cables or documentation on how to get the damn thing to work. The only thing I can see is a 4-pin input on the side of each screen that I would assume takes in power and video signal via some adapter. There are a couple of model numbers, one under that plastic piece next to the Sharp logo which is DUNTK2547TPZZ, the other is B2391A (which you can see in the pics below). Googling both of these didn't really get me anywhere, other than verifying that it in fact is a Sharp screen.
    Has anyone seen anything like this, or have any idea where to point me? Are those 4 pinouts common? Can I make an adapter to make it work?
    Below are some photos...
    Screen itself:
    Side of screen phantom input:
    Screen apart:
    Closeup of screen apart:
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    do you have a bottom side picture of that circuit board with the 4 pin plug on it?
    肚子笑痛了
    S60 Install
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Looks like the half-empty board is made specifically for in-car use of that panel...
    The connector probably takes +12v, ground and 2 inputs, or +12v, input and 2 ground pins.
    You should trace the pins' tracks to see where they go. I see some regulators and I guess the switches are for adjusting brightness and switching between 2 inputs (but i could be very wrong here )
    May 2003
    Miami, FL
    4 pins would be 12V+ Gnd Video and Video gnd, at least thats what I would assume
    肚子笑痛了
    S60 Install
    Jan 2004
    Florida
    There isn't much to see on the other side of the 4-pin, because there is a huge chunk of double sided tape that kept it in the housing...
    May 2003
    Miami, FL
    I wanted to see traces, but ok, can you take a picture looking straight down onto the white 4 pin connector?
    肚子笑痛了
    S60 Install
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    i should be able to help you out
    PC Components:
    My work log
    Dec 2004
    Maryland
    Not the best picture but it shows the grouping, the red on the end is the power, the white on the oposite end is from the pair for the video.
    PC Components:
    My work log
    Mar 2004
    Ghent - Belgium
    I don't see any red/white anywhere near the connector... or you must mean the wires coming from the inverter, going to the backlight, which certainly have nothing to do with 12v or video...
    Dec 2004
    Maryland
    sorry my pic was too big, its up now
    PC Components:
    My work log
  1. Replies: 5
    Last Post: 04-30-2004, 12:25 PM
  2. What the....same screen? Good screen?
    By Seabass in forum General Hardware Discussion
    Last Post: 03-31-2004, 12:37 AM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  4. NEC Versa M/75 Laptop TFT screen w/touch
    By Macgyver777 in forum LCD/Display
    Last Post: 03-24-2002, 03:14 AM
  5. Laptop/LCD screen hookup...
    By UrbanTacticz in forum LCD/Display
    Last Post: 11-28-2001, 06:49 PM
