Results 1 to 6 of 6
Thread: xenarc controller not being detected
    Constant Bitrate fallnangel's Avatar
    Richmond va
    ok screen works but ts wont work it cant even tell there is a controller. antone know how to fix this.?
    ..and dont back out just because u think its too crazi , i hate pussies
    -outdidya
    epia m1000,256mb ddr,7"lilli,120gb hdd, Ati remote wonder,400watt inverter,350psu all under xp pro-installed
    Richmond va
    when i plug the usb in nothing happens.jus sits ther as of nothing is in usb port,tried all my ports.
    -outdidya
    Jan 2004
    Check that your USB ports are actually working. Stick another device into the USB port and see if it picks that up. I had the same problem with my USB card. Took it out, rebooted, shut down and put it back in. On start up this time it detected it! Sometimes windows will not see stuff especially if you installed XP with the card in there.
    Raw Wave
    Jun 2004
    On the beach
    Do you have the correct via motherboard drivers installed??? If they are the default XP Drivers they don't always work - I had this on mine and it was because I hadn't installed the manufacturers drivers.
    Variable Bitrate euro320i's Avatar
    Apr 2003
    Near Frankfurt
    USB dirvers are finicky, you gotta install the driver before you áttach the USB device. What gives? I donno.. that's the way it is.
    o/______\o
    (oo_OO_oo)
    []o-----------o[]
    '94 320i
    Richmond va
    cool guys thanx for the advice thats a will do.
    -outdidya
  1. Please HELP!! PSU/ Shutdown controller questions
    By RJP350Z in forum Power Supplies
    Last Post: 12-23-2004, 03:37 PM
  2. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  3. Xenarc VGA Controller Features
    By 1300mer in forum LCD/Display
    Last Post: 07-05-2004, 01:46 PM
  4. Xenarc Touch Panel on Lilliput Controller
    By badandy4you in forum LCD/Display
    Last Post: 06-04-2004, 01:54 PM
  5. xenarc controller wire extension
    By G35Pimp in forum LCD/Display
    Last Post: 03-04-2004, 06:39 PM
