its the egg... its not getting enough voltage.. not joking neither.. check the voltage after the egg and you'll see about 6v.. seems the regulator splits into 2 tracks so 1 goes down and you still get half the power through...
Watch it though cause you run it too long and the extra current to turn the screen on needed from 6v will melt the cable.
Best option.. hock it to your pc's power supply and see if it then works.. if it does then you'll want a new regulated power supply.
LinkBack URL
About LinkBacks
