Results 11 to 20 of 24
Thread: Add on fan to Lilliput -- Power ?? where ??
  1. #11
    Maximum Bitrate ddogg_777's Avatar
    Apr 2003
    HOT Arizona
    I was thinking of adding a fan in the same place as Don an then hooking the fan to the speaker output. My fan is a 12V 0.06A fan so it draws less power than the 32ohm, 1W speaker that I took out. I want to do this because I can then use the volume buttons in the front to lower/raise the fan speed. As you technicals might guess, I need to hook up a signal to the audio input. My question is, how high of a signal? 1V, 3V, 5V, 12V?? My theory is to solder up a wire from the audio input to the power input, that way the fan will come on whenever the lcd is powered.
  2. #12
    Apr 2003
    HOT Arizona
    Here is a link to the IC amplifier on the board: http://www.semiconductors.philips.co...7052AT/N2.html
  3. #13
    Apr 2003
    HOT Arizona
    DOH! Scrap that idea, the volume buttons only work in video1/2, not vga.
  4. #14
    mox
    mox is offline
    Constant Bitrate mox's Avatar
    Nov 2004
    The Netherlands
    Quote Originally Posted by ddogg_777
    Now that audio can be enabled in VGA-mode through the hidden factory settings menu, I will look into the idea of turning the volume buttons into a fan speed controller. It depends on whether the signal on pin 4 of the TDA7052 ("DC volume control") can deliver enough current to power a 40mm fan directly. I'd suggest adding a darlington as a buffer anyway.
    CarPC status: HW all done, SW needs tweaked.
    Hardware: VIA MII-12K, 512MB, 60GB 2.5", CW-8123 DVD-CDRW, 7" Lilli ts, Opus 90W, BU-353 GPS, 802.11b PCI, USB bluetooth dongle, AverMedia AverTV Cardbus Plus, Morex Cubid 3677
    Software: RR, MM/FD
  5. #15
    Jan 2005
    Merseyside
    Quote Originally Posted by mox
    HOW? please do tell, as I've been wanting to find out for AGES.
    Thanks in advance,
    Baggers.
  6. #16
    Apr 2003
    HOT Arizona
    Sweet Mox, let me know what you find, I've pondered this too.
  7. #17
    Newbie 66miles99's Avatar
    May 2005
    Canada Eh!
    Isn't this thread for the sound in VGA mode codes you were speaking of...just my .02
    Lilliput Programming Guide, More Reset Codes
    Dell C600 laptop
    Dell C dock II
    7" Lilliput VGA TS
    JVC Mp3 Headunit
    Holux GPS
    ...Its all working now in the car but far from complete.
    [|||............] 35%
  8. #18
    Constant Bitrate vairu's Avatar
    Sep 2005
    Florida
    Awesome info! I'll probably do this one day just to make me feel better that the screen will run a little cooler. Where can i get a fan like that? Do regular stores sell ones that small? (Best Buy, Circuit City, etc.) Thanks
  9. #19
    Variable Bitrate super-fly's Avatar
    Feb 2006
    NJ
    has anyone tried hooking up the fan to the speaker output with any success
  10. #20
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    I know this thread is super old, but I got 3 Lilliputs also and Im thinking of doing this also. I had 2 fans blowing air in, but the screen still seemed to get hot, so now Im going to go head and remove the speaker and draw air out....
    Quote Originally Posted by ddogg_777 View Post
    No. Fans actually heat up the air as it passes through the blades. You always want the fan to suck so that the hot air from the blades is exhausted. The only reason you would want a fan to blow on something if it was wet. Evaporation comsumes a lot of energy, thus cooling whatever is wet. This is why you sweat and you feel cool when a fan blows on you. However, electrical components don't sweat.
    BTW, I was actually gonna do this to my Lilly too. Thanks for the pics Don!
    Does this also apply to PC cases? I was thinking of having a large fan blow air in, and other fans blowing air out. Should I reverse it and have the large fan draw the air out and the 2 smaller fans on the sides blow in?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
  1. Power Consumption For P4 MB?
    By almera in forum Newbie
    Last Post: 11-27-2004, 01:47 PM
  2. 86% Efficient AC-DC ATX supply
    By auto_robotics in forum Power Supplies
    Last Post: 11-25-2004, 03:16 AM
  3. Laptop-battery (14.4V) to power Lilliput (12V)
    By Danneman in forum Power Supplies
    Last Post: 08-21-2004, 09:15 PM
  4. Lilliput Powering On/Off problem
    By masch in forum LCD/Display
    Last Post: 05-09-2004, 12:55 PM
  5. Lilliput has no power. help
    By LudeAtude in forum LCD/Display
    Last Post: 02-09-2004, 02:06 PM
