You need to change the display settings on the monitor itself. Just use the controls on the r\front of the LCD
I had to reinstall windows on my carputer and I did it in my house with my normal crt monitor. Now when i moved to my car on my xenarc, the 800x600 displays wrong. I can not see 25% of my dekstop. Like the start button is below my sight and im unable to see it.
If i switch to 1024x760 or any other resolution, my entire desktop is viewable.
Now i know i had it set on 800x600 before i had to reinstall windows, so i dont know what the deal is.
Should the monitor be 'default' or should it be displaying some type of xenarc name?
solved my own problem. For some reason 800x600 on 60 refresh and the screen sets itself to 800x480 with the bottom half chopped off.
But if i set it too 800x600 with 75 refresh, it displays fine. Weird
i had the same problem =)
