Results 1 to 3 of 3
Thread: Xenarc 800x480 with 21 pixels off the edge
    Constant Bitrate bridqer's Avatar
    Nov 2003
    Maryland/Arizona
    Sometimes my screen shows that it has the 800x480 resolution but stretches the image pushing 21 pixels off the right side of the screen. This looses the one to one pixel aspect horizontally. To fix it I have to change the resolution to something else than switch back to 800x480, and/or do the auto detect on the xenarc untill it displays correctly. I have the epia mii and a pny geforce mx4000 card on a right angle riser card with the recent settings from xenarc's website. Has anyone else ever had this problem?
    '99 F-350 Crew 7.3L~'02 F-350 Crew 7.3L~ '04 Dakota SLT+ 4.7L
    MII12000opus120~MII12000opus120~MII10000opus150
    NA~Senao dual 7.4 ant~Orinoco Gold
    Pioneer~Pioneer~PG Octane-R R5.1MT
    Xenarc, Rikaline6010, Garmin OEM16 HVS, CoPilot10
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    When playing with Lilliput same way, I realized setting anything else but 72Hz refresh rate causes similar behaviour like you observe. You might try some different frequencies to see if it helps.
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    mine has done something similar once, though it didn't look like it streched it, the image simply was shifted a bit to the right so a bit on the right side of the screen was pushed off the screen and there was an unused part of the screen on the left, I just did an auto detect to fix it the time it did it.
    2005 Dodge Magnum RT, Samsung Galaxy Tab install
  1. 800x480 with Radeon 9200 & Xenarc
    By ayclens in forum General Hardware Discussion
    Last Post: 09-30-2004, 01:00 PM
  2. Xenarc 700TSV 800x480 Support
    By auto_robotics in forum LCD/Display
    Last Post: 08-27-2004, 01:33 PM
  3. Has anybody got 800x480 to work with ver2 xenarc?
    By ChrisC in forum LCD/Display
    Last Post: 10-25-2003, 05:28 PM
  4. More info on 800x480 mode for Xenarc...
    By InFix in forum LCD/Display
    Last Post: 08-27-2002, 09:54 AM
  5. Xenarc 800x480
    By bgelb in forum LCD/Display
    Last Post: 08-24-2002, 12:01 PM
