Results 1 to 10 of 11
Thread: install xenarc without back
    Nov 2004
    HOw do I install the 700tsv without using the back half of the housing? whats the best way to secure everything inside? I know the screen is held in with pressure clips, but what about the pcb's? Pic's would be great. Thank you.
    Nov 2004
    anyone? Please?
    Maximum Bitrate wi77iam's Avatar
    Jun 2003
    Chester Springs, PA
    When I installed mine behind the dash, I just wrapped everything with saran wrap and secured with a rubber band. It's been there for a year with no problems, so I guess it works.
    Nov 2004
    do you have any pictures?
    Illinois
    everything is held together by those 4 little clips your screw in. I dont have pics, but i actually just did mine today without the backing. If you open it up, you will notice the back comes off but the front and the actual internals still stick together.
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    I have a couple pics of a xenarc here:
    http://filebox.vt.edu/users/cholbroo/g35/
    Its held in place by those 4 pressure clips and 2 screws at the bottom to hold in the circuit board.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    _
    Mar 2004
    Little Elm, Texas
    you don't even need to worry about it......I didn't use the back of mine and never had a problem......but then again I guess I never thought about it being a problem.....I didn't think there was anything loose back there to worry about?
    Jan Bennett
    Nov 2004
    just checking thank you for all the info.
    Variable Bitrate Fraychild's Avatar
    Jan 2005
    Somewhere I Belong ~
    So basically, if you're not using the backing, you can just let all the circuitry hang out in the open? (Unless of course you know something may cause damage to it)...
    VER. 3.0- Check out below:
    車コンピュータ 3.0
    _
    Mar 2004
    Little Elm, Texas
    it's not like there are these little gnomes that live back there that will die if they aren't covered up....lol
    Jan Bennett
  1. what does the back of the XENARC TSV look like?
    By Sporttracguy in forum LCD/Display
    Last Post: 11-23-2004, 01:50 PM
  2. Xenarc Touch screen Question.
    By IntellaWorks in forum Input Devices
    Last Post: 11-10-2004, 01:19 PM
  3. pre-built Xenarc carputers any good?
    By ayclens in forum General Hardware Discussion
    Last Post: 07-07-2004, 10:44 AM
  4. Replies: 15
    Last Post: 03-03-2004, 12:53 PM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
