I have no idea what is causing it, but until you find a solution, you can avoid seeing the Windows XP loading screen if you are using XP SP2.
Run the System Configuration Utility (msconfig), go to BOOT.INI tab and select NOGUIBOOT.
Why don't send an email to you supplier, see if you can send it back (RMA).
LinkBack URL
About LinkBacks
