Results 1 to 10 of 15
Thread: Regulated or unregulated 12V for my display?
    Jul 2004
    How many of you are running your displays with unregulated 12V? I'm guessing most screens work just fine unregulated, but... that's just a guess...
    -momanz
    Constant Bitrate StationRocket's Avatar
    Sep 2003
    Rochester, NY
    i can't speak for all displays but i know many of them are designed to opperate off your car's normal 12v range. I have successfully ran a Xenarc off my car's unregulated 12V
    That being said some have had noise issues where there is sone alternator related noise in the image. Using a regulator or just running the display off the 12v rail from your pc power supply will filter it out.
    Constant Bitrate mpfjr's Avatar
    Jun 2004
    Corona, CA
    Well if you take the 12 volt car charger type plugin apart you'll notice that aside a resistor for the led light, there is nothing else inside to regulate the power.
    Thus, the regulator is built into the display. I am going to run my power through a filter just to clean it up a little but I am not regulating it.
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    mpfjr, That isn't true for all displays. If you input unregulated 12V into a display that doesn't have a built in regulator you are feeding it about 14.5V with the engine running. That's a good way to kill a backlight or any other sensitive electronics in a hurry.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    Jul 2004
    Hmmm. The box spec on my display claims an operating range of 11-24 volts... so I'm guessing I'm ok. I'll be ready to do my initial testing this weekend so we'll see how it works out. BTW I have a starvision sp-7vga. Not the best display I've read about, but it was cheap and yes a bit of an impulse buy too.
    -momanz
    Raw Wave EsKALad's Avatar
    Jan 2005
    Chicago, IL
    i have a lilliput 8 inch that when i wire str8 to the 12v with or without egg it flickers. i tried using the ac adapter and it works fine. but my problem is now i have to use a small inverter to plug the ac adaptor into. i dont want to do that. any suggestions? im looking for a regulator i seen the carnetix. but isnt that too much unnecessary power for just 1 screen? and input would be great!!
    Sep 2003
    Rochester, NY
    you could try one of these
    http://www.partsexpress.com/pe/showd...number=265-030
    or is that what you meant by "egg"
    Maximum Bitrate DeltaFX's Avatar
    France
    Eskalad, why don't you power your screen from a molex 12v ?
    Maximum Bitrate VanMan69's Avatar
    May 2004
    Alameda, CA
    Xenarcs are marked 11-24V. I've been running mine unregulated.
    95 Chevy G20 Vroom Boom Room
    ...with a whole bunch of nifty ****... go check it out: VanDomain Page
    Jan 2005
    Chicago, IL
    delta how would i go about doing that? wiring from the molex? which wires? can u draw me out a diagram?
  1. 12V, 5A Regulated Car Adapter
    By Alta in forum Power Supplies
    Last Post: 03-03-2005, 01:02 PM
  2. Urgent: who sells 12v regulated Lilliput lead
    By SteveC in forum General Hardware Discussion
    Last Post: 09-27-2004, 06:51 PM
  3. pw-120/200 needs 12v regulated?
    By hcker2000 in forum Power Supplies
    Last Post: 09-09-2004, 04:59 AM
  4. Replies: 15
    Last Post: 08-07-2004, 10:09 PM
  5. Regulated/ unregulated relay switch?
    By mp3oplecarrier in forum Power Supplies
    Last Post: 06-01-2004, 10:05 PM
