That LCD BIOS setting is for the EPIA motherboards. Don't worry about it. If your DIN connector is tight and a higher refresh rate didn't fix the flickering then I bet it's your power. If you are using the DC "egg" regulator then try using the AC adapter on an extension cord. If the flickering goes away then you need a better DC regulator. The supplied DC regulator is crap.
LinkBack URL
About LinkBacks
