Results 1 to 9 of 9
Thread: Lilliput noise
    Dec 2004
    Los Angeles, CA
    Lilliput noise
    Hi, I just installed my lilliput tv. it works PERFECTLY when the engine is off, but when I turn it on, I am getting noise on the screen. Lines are running up and down it. Anything I should do?? Should I ground it?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Grounding will help. Search about cutting off the lilliput egg.
    Dec 2004
    Los Angeles, CA
    See, I heard about the egg causing problems, but have you ever seen this type of problem before? Doesn't have any problems when the key is on and working, but when the car ignition is turned on and I'm driving, I get noise.. Very weird!!
    Jul 2004
    Berkeley, CA
    You are getting alternator whine. Cut off the egg and hook your lilli to your PSU.
    Constant Bitrate Trazer's Avatar
    Jul 2004
    The Netherlands
    Quote Originally Posted by 0l33l
    True, i had the same problem. Connected it to my carnetix and the problem is completely gone.
    There ain't no need to cry. Time's up. It's time to die....
    Jul 2004
    Berkeley, CA
    Quote Originally Posted by Trazer
    And I don't even have a lilliput
    Dec 2004
    Los Angeles, CA
    UPDATE: FOUND A NEW WAY TO CUT NOISE!!
    Instead of having it run at True Color 60 Hz, change it to > 75. Works PERFECTLY now!!
    Constant Bitrate strohmrs's Avatar
    Jun 2004
    Idaho
    Glad it worked for you. The refresh rate doesn't help everyone and with time the egg will cause problems. It is a cheap design and prone to interference from just about anything.
    Rick S.
    XP Pro SP2, Soyo P4RC350 MB, Nvidia FX5200, 320W PS, Inverter & uSDC20D, 2.4GHz CeleronD320, 512MB DDR, 30GB 3.5", Pioneer 106s Slot DVD, Linksys WMP54G WiFi, Lilliput 7" & 4" TFT LCD, Zippy EL610 Keyboard, Touchpad, Garmin GPS V
    Oct 2004
    so i cut the egg and then hook the two wires coming from the lilliput to the psu?
    i have a opus. which wires would i tap into?
    anyone know the colors?
  1. 8" Lilliput adds noise to my stereo
    By MSUC5Vette in forum LCD/Display
    Last Post: 10-11-2004, 04:33 AM
  2. Lilliput egg noise, solutions?
    By johnnyutah36 in forum General Hardware Discussion
    Last Post: 08-24-2004, 02:24 AM
  3. Noise in Lilliput from HDD
    By zvi in forum LCD/Display
    Last Post: 07-14-2004, 01:17 PM
  4. Lilliput causing engin noise
    By eazyrog in forum LCD/Display
    Last Post: 06-07-2004, 09:58 AM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
