Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Connect PSOne LCD Screen to PC
    Feb 2005
    Hi, new to the forums. I want to hook a PSOne LCD screen to my PC. The problem is I don't know how I should regulate the power to 7.5v. I'm guessing some kind of DC-DC converter that will do 12VDC->7.5VDC. Anyone have suggestions on what part(s) to use or any other solutions. Thanks.
    Variable Bitrate Osiris's Avatar
    Atlanta (kennesaw) GA
    How are you powering your PC? I think that carnetix regulators has an extra plug-in that may do the job for you. Someone verify or correct me on that.
    Osiris Networx
    --Tuning is all about price vs performance. You've got to find your own medium.--
    Feb 2005
    Pretend I just had the 5v and 12v source given by the power supply. Simply because I do .
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    Go to any game store and pick up one of those cig power adapter for PSOne. Otherwise buy one of those universal/multiple output from wallmart/radiosuck and well game store.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Mar 2004
    Well, if you could put +12 on the positive and +5 on the negative for 7V...
    Dunno if that would actually work.
    Oct 2004
    South Carolina
    +12v for postive and +5v for negative would give you 7v of power, I would assume that would work
    (from a standard molex connector in a computer, 12v is yellow, 5v is red)
    Dec 2003
    couldnt u use a resistor? i think its ohms law. volts/amp?
    Feb 2005
    Um, are you sure about the 7v thing? That...doesn't sound like it'd work. Sounds more like it'd short out. I'll try it anyhow because my lcd screen appears to be broken.
    Feb 2005
    Yeh, I didn't do it with the LCD screen, and just as I thought, it created a short(NOTHING FRIED )
    Oct 2004
    South Carolina
    how did it create a short? it's not supposed to. the only thing that happens is the voltage drops to 7 volts. that's an easy "fan speed hack" if you want to quiet the fans in your computer down, instead of running at their full 12 volts.
    yellow wire is 12v, red wire is 5v (from a molex connector coming from the computers PSU)
    you should be able to hook up the 12v where the positive should go to the psone, and then the 5v wire should go to where the negative should go to the psone screen.
    no shorts, just the difference in volts. I don't know if this would power the screen, but it does not create a short. you can try googling 7v fan speed hack or something to get more info
  1. Wild Things PSone LCD to PC
    By godzi11a in forum LCD/Display
    Last Post: 11-22-2005, 08:13 PM
  2. FS: Tablet PC (8" TFT LCD)
    By BimmiN in forum Classified Archive
    Last Post: 10-25-2004, 01:04 AM
  3. Finally some success with LCD psone screen
    By PierreLo in forum LCD/Display
    Last Post: 06-29-2004, 05:53 AM
  4. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  5. Car Environment Temperature vs LCD screen, PC??
    By dekodan in forum General Hardware Discussion
    Last Post: 08-01-2001, 03:46 PM
