Hey tbird,
Double check the freqeuncy your card is pushing out - sounds like it is set to high, try lower like 60Hz or 75Hz, also check whether the correct drivers.
I just redid my carputer (as in formatted and reinstalled XP). Before I did that I ran it at 800x600 with no problems. Now when I try to run it at 800x600 my Xenarc detects it as 800x480 and cuts off a lot of the screen. It runs at 640x480 fine.
How do I get it to run at 800x600 again? I didn't have problems before?
Current Vehicle: 2007 Dodge Nitro
Second Vehicle: Sold it :( 2005 Dodge Ram 1500 Quad Cab
First Vehicle: 2003 Ford Ranger
Hey tbird,
Yep, try different frequencies. I think 75mhz is what you need to get 800X600.
Want to:
I've tried changing the frequency to 75mhz and just got a black screen.. I've also tried the 3.2.3 and 3.2.2 drivers from Xenarc's website and I still got nuttin...
Did you try auto adjust?
Want to:
I tried setting it to 75 again and that worked.
Thanks a lot!
