Results 1 to 7 of 7
Thread: Lilliput 7" or 8"
    Feb 2005
    Lilliput 7" or 8"
    I've noticed everyone seems to go for the 7inch. Whats the difference between the two and what would you all reccomend. Its being fitted to dash via a car phone mounting bracket, so size isnt an issue.
    Jesus Freak antimatter's Avatar
    Jan 2004
    California
    go with the 8"
    i haven't heard any problems with them...the 7" on the other hand....nothing but problems. I own 2 that work though
    Jan 2005
    What problems?
    The three main problems I have heard about are all through user error really.
    1. People screwing them up when fiddling with the wiring which is just carelessness really.
    2. Fried by power problems when people dont use them with a stable 12v supply which is again down to the user (and most probably only blows out the small fuse which is fiddly but replacable)
    3. Lastly problems with drivers because they tried to use the dodgy supplied ones rather than downloading the ones that actually work.
    All of these are avoidable if you take the time to read the lilliput faq rather than rushing right in.
    The advantages the 7" has is that it's widescreen which is better for movies and reverse camera, and that because it is smaller it fits in a double din hole in case you want to install it in the dash.
    The main disadvantage would be that because its widescreen you have to deal with the squish or an odd screen res although most carputer software handles that.
    Personally I think the 8" is too big even when on a seperate mount.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    erm what about the power problems from the egg being a load of crap
    the touchscreen going dead on one side and/or slipping out of calibration
    and the wiring problems are because the connectors were not soldered to the boards properly or the connectors used to be crap.
    Oh and there have been problems with dry joints.
    Maximum Bitrate Frankino's Avatar
    Nov 2004
    Italy
    the 8" unit is 640*480 native
    the 7" is 800*480 native
    8" in 800*600 does not look so well, acceptable but not very clear
    Peugeot 206 1.4 HDi
    Intel Mini-ITX Mainboard
    Celeron 1.2ghz
    256mb DDR-2 533
    80gig 3.5" SATA HDD
    Sb Live 5.1 w/ KXProject Drivers
    M2-ATX
    8" Lilliput TS LCD
    100% installed and working :D
    Feb 2005
    Thanks for your help so far.
    7" sounds like it would be better, purely because of resolution.
    I think that is what I will go for thanks.
    Stank Cheese n8scstm's Avatar
    Oct 2004
    Eastvale, Ca (Near Corona)
    I have an 8" and think the resolution looks great. I went with the 8 inch because my stock stereo was a 1.5 din so the 7 inch wouldnt have fit anyway. So I was gonna have to move the a/c controls. Therefor the 8 inch was a better fit. Plus it really is a lot bigger and in my opinion more touch screen friendly because of the size.
    2.4 celeron
    150 watt OPUS
    micro atx
    xp pro
    tv/radio tuner card
    audigy
    Dual monitor Radeon
    802.11G Mimo
    xm pcr
    dvd
    gps
    8" Lilliput touch screen
    IGuidance
    dual optimas
    battery isolator
    15" screen
    My Truck
  1. Lilliput 7" or 8"?
    By Gredd in forum LCD/Display
    Last Post: 12-13-2004, 04:49 PM
  2. WTB: Lilliput 7" or 8". Used but perfect, I´m in Argentina
    By guillemasco in forum Classified Archive
    Last Post: 12-06-2004, 01:45 PM
  3. Replies: 7
    Last Post: 11-19-2004, 12:32 PM
  4. running 7" and 8" lilliput together
    By dexy in forum General Hardware Discussion
    Last Post: 09-29-2004, 07:16 PM
  5. Replies: 5
    Last Post: 04-01-2004, 05:37 AM
