+ Reply to Thread
Results 1 to 7 of 7
Thread: Tutorial: Forcing Custom Resolution in Windows
    Feb 2005
    Atlanta, GA
    In case this has not been covered here, I am posting this for the benefit of everyone. I'll add an appendix or additional information if needed to a certain extent.
    DISCLAIMER - Do this at your own risk! The forum owners, moderators, myself, nor anyone else can be held responsible if this causes ill effects or damage to your software setup, OS setup, or hardware. Changing configurations in the Windows Registry (Regedit) can be dangerous if improper settings are used and should be done only by someone that knows how to work within Registry Editor. Damage to your monitor may result from setting resolution, color depth, and/or refresh rate higher than the monitor’s capabilities. Improper settings in other areas of the Registry not covered by this tutorial may result in your OS not functioning properly or unable to boot to Windows
    DO THIS AT YOUR OWN RISK
    Abstract:
    Monitor resolution, color depth, and refresh rate available in the Display Properties are defined per the drivers for the video card. From there PnP or the system administrator may limit higher options that the monitor does not support to prevent accidentally changing a setting that may potentially damage a monitor or force the monitor to turn off to protect the hardware. The driver for the video card generally only sets standard 4:3 resolutions (640x480, 800x600, 1024x768, etc.) and doesn’t normally set 16:9 resolutions (800x450, 1024x576, 1280x720, etc. ) or 16:10 resolutions (800x500, 1280x800,1680x1050, etc.).
    This document describes the process of defining a custom resolution within Windows and can be used to define the native resolution for a monitor that does not natively display a 4:3 aspect ratio.
    Access Requirements:
    You must have Administrator access to the machine to make these changes.
    Procedure:
    1. Click on Start, then Run
    2. Type in regedit in the Open box, then hit [Enter]
    3. Expand down to HKEY_CURRENT_CONFIG\System\CurrentControlSet\Contr ol\VIDEO\{Hexadecimal number for your primary video card}\0000
      • Note: Under VIDEO will be one or more registry keys that have a long hexadecimal number; this is the Hexidecimal number assigned to a specific physical or logical video card. There may be more than one if video cards have been changed or a major driver update has been performed. The key that has the current setting should be the one that needs to be modified.
    4. Double-click DefautlSettings.XResolution, change the Base from Hexadecimal to Decimal notation, and set the X axis.
    5. Double-click DefautlSettings.YResolution, change the Base from Hexadecimal to Decimal notation, and set the Y axis.
    6. Reboot
    • Note: If settings did not take effect, modify a different video card in the registry
    • Note: If monitor ceases to function upon Windows coming up, reboot and go to Safe Mode. Pull up the registry and change the settings that were last modified back to the way it was or change the resolution to a safe resolution such as 640x480.
    Raw Wave Confused's Avatar
    Aug 2003
    Essex, England
    Thanks for the information.
    However, the biggest problem is that many people are using VIA Epia boards, which do not, via ANY means, support custom resolutions. Either added via drivers, PowerStrip or natively in Regedit (all do pretty much the same thing, some with more automation than others)
    It's worth a try, but don't get your hopes up.
    Garry
    Co-Developer of A.I.M.E.E
    www.aimee.cc
    Feb 2005
    Atlanta, GA
    When I get my hands on a EPIA motherboard, I'll check it out. I hate to think this wouldn't work with the intergrated video. Well it's nothing a sledgehammer couldn't fix.
    Variable Bitrate checksum's Avatar
    Feb 2006
    Columbia/MD
    Hello,
    I have windows 7 running and I could not get this to work.
    I went into the registry, and this is what I see:
    There is no Hexadecimal number listed under Video, all I see is (Default) on the right hand side.
    I tried adding the X and Y values under (Default), but that did not work.
    Could you please help. My native resolution is 800X480 and it is not listed under Windows Screen properties.
    Maximum Bitrate Caelric's Avatar
    Sep 2005
    Bellevue, NE
    Ever get this to work for Win 7?
    2005 Infiniti G35 6MT Coupe Black/Black
    Core Duo CarPC
    CarDomain page
    Low Bitrate Strgazr's Avatar
    Mar 2004
    Blanchard, OK
    Win 7 - try right click on desktop, Screen Resolution, Advanced Settings, List All Modes. If you don't have it set on the auto accept and it doesn't work, it will revert in 15 seconds.
    Sep 2005
    Bellevue, NE
    Worked! Thanks, I appreciate it
    Core Duo CarPC
    CarDomain page
+ Reply to Thread
  1. Custom App Resolution
    By camsgs3 in forum Software & Software Development
    Last Post: 12-06-2004, 01:25 AM
  2. gps customizing and custom resolution? advise wanted
    By yunusyu in forum General Hardware Discussion
    Last Post: 05-29-2004, 06:09 PM
  3. Custom Windows resolution
    By Toups in forum LCD/Display
    Last Post: 04-21-2004, 03:38 PM
  4. VIA EPIA with custom (16:9) resolution
    By SuperG35 in forum LCD/Display
    Last Post: 02-04-2004, 08:03 PM
  5. ME v2 will support custom resolution?
    By iPal in forum ME Archive
    Last Post: 10-06-2003, 09:10 AM
