Results 1 to 10 of 10
Thread: Is 640x480 stupid on a xenarc ?
    Nov 2004
    Yo fellows ,
    I am encountering the following problem, i am using a xenarc 700 TS on a via epia10000 board, the board and the xenarc is powered by a OPUS 90W. Now when i put my resolution on 800x600 or 1024*768 on 75Hz, 1/2 of the time the xenarc does not behave like it should : it replaces the screen image about 3-4 cm to the right. the only thing i can do is auto adjust the screen by the buttons on the screen. no the problem is, i have bondo'ed these buttons away. The only solution i found was putting the screen on a 640x480 resulotion on 60Hz, now the screen always shows the image the correct way. I am using frodo as front end, and frodo turns out to work great on 640x480, but i would prefere runing it on 800x600 because this is te resolution most skins are build for. Are there any solutions ?
    thnx in advance ....
    Jan 2003
    Ruston, LA
    try changing the refresh rate
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    I would try 800x600 at like 70hz. and there is no way at all you can get to the buttons?
    肚子笑痛了
    S60 Install
    Dec 2004
    800x600 at 60Hz doesn't work for you? That should be the refresh rate at which the Xenarc is happiest (as is the case with many, many LCD panels), and I've had no autodetect problems at that res. Not to imply that you don't already know this, but as LCDs don't flicker the way CRTs do, there's not much point in running the Xenarc about 60 Hz. Hope that helps...
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    You need to get those buttons back...
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    I think your only solution is to get at those buttons....
    Want to:
    Jan 2005
    Federal Way, WA
    Why did you get rid of the buttons in the first place?
    FLAC aoLhaTer's Avatar
    Mar 2003
    Rohnert Park, CA
    Dont the Xenarcs come with a remote?
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    pinhole through the bondo to actuate the buttons .... why bondo over them anyway ??
    Nov 2004
    first of all thnx for the reply's
    second : I can get to the buttons if i really wont to, but i need to do this 1/2 of the time... (auto adjusting the screen) and this is really frustrating me. now i am running at 640x480 and i don't need to do it any more ... but i would like it more running at 800x600 .....
  1. Xenarc direct cause of audio noise- help!
    By shidarin in forum LCD/Display
    Last Post: 04-19-2008, 10:53 AM
  2. Stupid Xenarc! It won't turn on when laptop is on or display correct!!
    By PDiddy in forum General Hardware Discussion
    Last Post: 01-17-2005, 08:53 PM
  3. Replies: 88
    Last Post: 09-15-2004, 06:38 PM
  4. FS: Xenarc 700TSV touch UXGA capable
    By cproaudio in forum Classified Archive
    Last Post: 01-20-2003, 07:38 AM
  5. Xenarc Meta FAQ
    By Skippman in forum LCD/Display
    Last Post: 08-23-2002, 04:11 PM
