Results 1 to 3 of 3
Thread: Extending the internal cables in TFT screens
    Oct 2003
    Copenhagen, Denmark
    Has anyone attempted to make the ribbon and backlight wires longer from the LCD screen to the controller internally in the case ? I want to use the module about 3 inches from the controller itself.
    Jan
    Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
    Nov 2004
    Netherlands
    Quote Originally Posted by _dopehead_
    Jan
    Backlight cables can be extended without problems, only take care since the cables between inverter and CCFL use high voltages, so use proper cabling.
    Extending the other cables is somewhat more difficult: Depending on the cables used you have to solder it yourself. There are some extensioncables available, or you can make one yourself, but it requires some soldering skills.
    I did it once myself (to get an old TFT on a overhead projector, so it's now a beamer). A micro soldering iron is advised, since I had to solder 20 wires on a 1 cm width cable (0.5mm connectors.. so its small)
    The regular FFC extensioncables can be found on some DIY-beamersites, like www.lumenlab.com and/or www.diybuildergroup.com
    The connectors and cables itself can be ordered at Farnell. (dunno about USA shippings). My screen needed a 20pins 0.5mm dotpitch cable/connector, which my local electronics shop ordered for me at Farnell ( www.farnell.com ), productno 3078413 (connector) and 3295035 (cable)
    Oct 2003
    Copenhagen, Denmark
    Thansk DJsmiley, i think i have a local supplier of the ribbon cable in different sizes. So i'll just use some heavier duty cable for the CCFL.
    Jan
  1. Belgian Shop to buy small TFT screens ?
    By H3nrY in forum LCD/Display
    Last Post: 05-31-2007, 08:05 AM
  2. Rewflective TFT Screens
    By antimatter in forum LCD/Display
    Last Post: 06-07-2004, 01:22 AM
  3. whats VGA TFT screens are there?
    By Jake in forum LCD/Display
    Last Post: 09-29-2002, 03:02 PM
  4. 5.6Inch TFT screens with stand for $425AUST!
    By magnetik in forum LCD/Display
    Last Post: 03-17-2002, 08:08 PM
  5. TFT screens in Australia.
    By magnetik in forum Classified Archive
    Last Post: 09-05-2001, 04:57 AM
